RCU Forums
-   Electric Indoor & Micro RC Flight (https://www.rcuniverse.com/forum/electric-indoor-micro-rc-flight-182/)
-   -   Help with setting rudder & elevator in DSM2 micro brick receiver/servos (https://www.rcuniverse.com/forum/electric-indoor-micro-rc-flight-182/11597300-help-setting-rudder-elevator-dsm2-micro-brick-receiver-servos.html)
ARillos 04-07-2014 02:19 PM
I am transferring the electronics from a 4-site micro plane to a scratch built Frog Raven using only rudder and elevator from the DSM2 brick receiver/servos. The problem is that the rudder is working but it is in the left stick, as it is supposed to be, but since the plane do not have ailerons I would like to have the rudder working with the right stick as ailerons. Maybe that is a silly question but I could not find an answer so far. I am using a Spectrum DX8 transmitter. Any help would be appreciated. Thanks. Alex.
coriolan 05-18-2014 07:23 PM
With the DX8 you can do a 100% mix of aileron>rudder!
