XPV HELP! ADVICE! SUGGESTIONS!
Need some advice and help.
Bought an XPV IN Walmart $2.00 It says FlyWheelS RTF but it was without controller, battery and charger.Usually they sell for 59.95. Will a conroller from a mini XPV work if its 27 MHz the same as the new XPV and what to do on a battery. Will the new Bigger XPV that comes with the battery and charger work with this fly wheels XPV plane? Maybe I bought parts only. Can someone get me running??? |
RE: XPV HELP! ADVICE! SUGGESTIONS!
Found out the mini controller will work and the 500mah battery will work. Now I need a weight for the original battery and the mah for the original battery. Hope someone can help ith this!
