Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Lightning Build
Old 11-10-2012, 11:15 AM
  #426
Viper Driver's Avatar
Default RE: Lightning Build
Robert,
Plans should be in your email.
Jeff
OSU alum and huge Beaver fan!
Old 11-10-2012, 01:43 PM
  #427
Cool thanks!
Half time right now. I must be the official Beaver Southern California fan. Am I bad when I see a big O on the back of a car I have to pull in front of it so they can see my orange beaver sticker?
Robert
ORIGINAL: Viper Driver
Robert,
Jeff
Old 12-03-2012, 08:21 PM
  #428
Hi
any chance of getting the plans still if so can you send them to flier81 @hotmail .com
Matt
Old 12-15-2012, 12:01 AM
  #429
papaone's Avatar
Hello
Building by Panzi, great job !
http://www.rc-network.de/forum/showthread.php/301355-Selbstbau-des-F3A-Modells-Lightning-%28Holzklasse-!-%29?p=2975256#post2975256
Claude
Old 12-15-2012, 05:50 AM
  #430
Looks like Panzi is moving right along. Thank you for heads up Claude.
Jeff
Old 12-15-2012, 10:03 AM
  #431
I'm working on the FIN - and have a few quick questions.
The rib diagrams include FN-1 , but FN-1 doesn't show up in the plans, and I didn't see it in your picture of your fin build.
I suspect this part is no longer needed, correct?
Old 12-16-2012, 05:57 AM
  #432
John,
You are correct, FN-1 is not required. It was left over from the design process.
Jeff
Old 12-23-2012, 12:10 AM
  #433
Thank you! It is really fun to build that great aircraft. As you have seen i had already wings and elevator unit from the Xaros a plane witch is build from a friend of mine. So i had to change the wing tubes. Also a T-canard is planed. But i wonder how you finisched your fuselage with 581g!! How light where your balsa sheets?
So thank you Jeff for having the oportinity to share your plans with us!
Panzi
Old 12-23-2012, 06:59 AM
  #434
Panzi,
The key to minimizing weight in the the fuselage was mostly due to balsa wood selection. I ordered 25% more wood than I needed so I could select only the lightest. The difference between the lightest sheets and the heaviest sheets for the fuselage sides was about 60 g. I adds up quickly. If I recall correctly, my 36 inch by 4 inch by 1/8 sheets were between 19 and 21 grams.
Good luck with the build.
Jeff
Old 12-23-2012, 01:08 PM
  #435
<span class="hps">hello</span> <span class="hps">jeff</span>
<span class="hps">great job</span>
<span class="hps">I</span> <span class="hps">also</span> <span class="hps">would like to build</span> <span class="hps">a</span> <span class="hps">lightning</span>
<span class="hps">you</span> <span class="hps">have</span> <span class="hps">plans?</span>
<span class="hps">thanks
maurizio /</span>italy
[email protected]
<span class="hps">ps</span><span>: sorry</span> <span class="hps">for English</span> <span class="hps">I used</span> <span class="hps">google</span> <span class="hps">translator</span>
Old 12-25-2012, 07:29 AM
  #436
<span class="hps">thanks</span> <span class="hps">jeff</span>
<span class="hps">got</span> <span class="hps">plans</span>
<span class="hps">I'm happy</span>
<span class="hps">Merry Christmas</span>
<span class="hps">greeting</span>
<span class="hps">thanks again
ps:<span class="hps">I finish my</span> <span class="hps">pitts</span> <span class="hps">m12</span>
<span class="hps">beginning of</span> <span class="hps">the lightning
http://www.baronerosso.it/forum/aero...ts-m12-3d.html</span></span>
Old 02-21-2013, 07:23 PM
  #437
Jeff,
CanI get a set of the lightning plans from you? I'm getting back into the hobbyand woudl like to try out this design. My old pattern plane was a Dr. Jekyll but I really like the new electtric stuff!
Old 02-22-2013, 06:03 AM
  #438
Bellboy,
Check your PM.
Old 02-22-2013, 11:24 PM
  #439
papaone's Avatar
Hello
German Lightning
http://www.rc-network.de/forum/showthread.php/301355-Selbstbau-des-F3A-Modells-Lightning-%28Holzklasse-!-%29?p=3045824#post3045824
ID:	1855202   Click image for larger version
Old 02-23-2013, 08:47 PM
  #440
Hi Jeff,
Can i also get plans for the Lightning plane, would love to build one.
Harry
Old 03-10-2013, 10:59 AM
  #441
Hi Jeff
Been reading this thread, very interested in building one.
Are plans available? If so email address below
[email protected]
Old 03-10-2013, 06:43 PM
  #442
Wouldman,
Check your email.
Jeff
Old 03-11-2013, 06:59 AM
  #443
Greetings from Germany
Thank you Jeff for the plans, my plane is ready for flying (when the snow is gone!)
http://www.rc-network.de/forum/showthread.php/301355-Selbstbau-des-F3A-Modells-Lightning-%28Holzklasse-!-%29/page16
Hans
ID:	1860706   Click image for larger version
ID:	1860707   Click image for larger version
ID:	1860708   Click image for larger version
ID:	1860709   Click image for larger version
Old 03-11-2013, 04:41 PM
  #444
Hans,
Thank you for posting pictures, it turned out great! I hope you get to fly it soon.
Jeff
Old 03-12-2013, 05:58 PM
  #445
Hi Jeff
I really enjoyed your build thread .How do I get a copy of your plans?
[email protected]
Thank you
Bruce
Old 03-16-2013, 06:27 AM
  #446
Looks great Hans! Getting ready to start mine soon. Already have the foam core for the wings. I was going to change the colors because they have already been done but I really like that color scheme!
A beaver would look good on the tail though
Robert
Old 04-16-2013, 04:58 AM
  #447
Hey Jeff thank you
ID:	1872634   Click image for larger version
Old 04-16-2013, 06:37 AM
  #448
My Feedback: (45)
Gerald,
That looks awesome. We'll figure out the graphics for it this weekend and get it ready to go. Jeff, do you know what font you have been using on yours?
Arch
Old 04-16-2013, 06:45 AM
  #449
Gerald,
That looks fantastic, I can't wait to see the entire thing.
Arch,
The font I use is called Bellboy.
Good luck with the rest of the project!
Old 05-01-2013, 03:25 PM
  #450
Hey Jeff,
Where did you get your carbon fiber sheets? From here?
http://www.cstsales.com/uni_carbon_fabric.html
web binding, net binding? Does it matter?
Robert
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
