Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Lightning Build
Old 08-16-2013, 01:12 AM
  #476
Jeff .... Thank you for the plans.
Gerry
Old 08-19-2013, 12:18 PM
  #477
Hi Jeff ,
Any chance I could get a copy of the plans ? I have always wanted a pattern plane but always wanted to build. The lightning looks awesome !
[email protected]
Thanks , James
Old 08-20-2013, 06:15 PM
  #478
Jeff , Thanks for the plans. They look great !
James
Old 08-23-2013, 08:30 AM
  #479
mnevzat's Avatar
Jeff, many many thanks for plans. So I also now have a F3A!!!!
I have a question to anyone, where is CG point for this F3A?
Thank you.
My works for F3A and final.
https://www.hobbyrc.com/forum/thread...9#.UheNktKzJI4
ID:	1911968   Click image for larger version
ID:	1911969   Click image for larger version
ID:	1911972   Click image for larger version
ID:	1911973   Click image for larger version
ID:	1911974   Click image for larger version
ID:	1911975   Click image for larger version
ID:	1911976   Click image for larger version
ID:	1911979   Click image for larger version
ID:	1911980   Click image for larger version
ID:	1911981   Click image for larger version
ID:	1912010   Click image for larger version
ID:	1912011   Click image for larger version
ID:	1912012   Click image for larger version
ID:	1912013   Click image for larger version
Old 08-23-2013, 08:32 AM
  #480
I believe it's on the plans.
Old 08-23-2013, 08:37 AM
  #481
mnevzat's Avatar
Unfortunately I couldn't see.
Old 08-23-2013, 08:41 AM
  #482
On sheet 2 of 6 the fuselage where the wing is. There is a black and white circle symbol. See attached
Old 08-23-2013, 08:57 AM
  #483
mnevzat's Avatar
Many so thanks kingconsulting. You were very helpful me.
Old 08-25-2013, 07:04 AM
  #484
Viper Driver's Avatar
Mnevzat,
Very nice work fitting the engine and pipe in the airplane and great job overall. Let us know how it flies.
Jeff
Old 08-25-2013, 11:03 AM
  #485
mnevzat's Avatar
You can be sure, I will publish soon.
Old 08-25-2013, 01:42 PM
  #486
Jason Arnold's Avatar
That 140Rx hard mounted, is going to vibrate the hell out of the airframe. You should consider some sort of soft mounting for the engine and pipe.... A Hyde type soft mount and nose ring would be the easiest install based on your pictures. Budd Engineering also have a suitable solution.
Cheers,
Jason.
Old 08-25-2013, 03:01 PM
  #487
mnevzat's Avatar
Jason,
Many thanks for your interest and inquiries.
I have built firewall 3*4mm plywood laminate.
The pipe coupling to engine two O-ring and with bed. And draws two spring. No any hard connection.
Do you think, can I still change?
I'm sorry for my not very well English.
ID:	1913083   Click image for larger version
Old 08-25-2013, 08:14 PM
  #488
My Feedback: (53)
Dansy's Avatar
Having run the OS 140RX for a number of years (and the YS's).....back in the 2000"ish.....I would definitely soft mount the pipe and the engine....otherwise I don't think the electronics would be happy for very long.
Old 08-25-2013, 11:00 PM
  #489
mnevzat's Avatar
Messrs, thank you for your valuable comments and suggestions. I'm going to fix soft mount after maiden.
Old 08-28-2013, 11:27 AM
  #490
mnevzat would you make canopy and nose piece for sell ti usa thanks roadrunner
Old 08-28-2013, 12:38 PM
  #491
mnevzat's Avatar
It may be possible. For details, see you via email.
[email protected]
Old 08-29-2013, 05:57 AM
  #492
good morning getting ready to buy the balsa needed for build does any of this need to be contest balsa or just normal balsa thanks steve
Old 08-29-2013, 06:38 AM
  #493
My Feedback: (45)
To really get the ultra low weights Jeff is known for, you will need to select the best and lightest balsa you can get. I know Jeff is extremely picky about what he uses.
Arch
Old 08-29-2013, 07:05 AM
  #494
mnevzat's Avatar
Good morning Steve. (Good evening about of here.)
I don't know, will it be enough my English to tell them ?
Balsa sheets for this work to be of medium hardness. Separetly you have to need 3mm plywood for canopy and cowling of main carrier.
Steve, I say here is topic for Jeff and we don't contaminate here. If you want subscribe to below link, you can look through my works and we can comment on them and I can explain some things on them.
https://www.hobbyrc.com/forum/thread...9#.Uh9jpNKzJI4
Old 08-29-2013, 07:46 AM
  #495
Roadrunner,
Arch is correct, the absolute lightest balsa wood is critical to achieving the lightest weight. I order an extra 25% of the wood I need, and then I weight each sheet before I use it in the airplane. As an example, I saved 1.5 ounces just by selecting the lightest four sheets to make the fuselage sides. Those grams saved here and there add up over the course of a build. The difference between 10 pounds 14 ounces and 10 pounds 2 ounces is very noticable.
Jeff
Old 08-30-2013, 02:44 PM
  #496
dloostler's Avatar
I ordered the lightning short kit today from eureka. I am going with the Hacker A60-7S V2. What mods am I going to have to make in the nose to put this motor in? what size of wing tube do I need and where can I get this? Any help would be appreciated Thanks
Dale
Old 08-30-2013, 06:57 PM
  #497
Dale,
The wing tube is 7/8" from F3A Unlimited. To put the outrunner in, you will have to use the firewall labeled Plett F-2. The exact position may have to be adjusted slightly to fit your motor.
Jeff
Old 08-30-2013, 07:12 PM
  #498
dloostler's Avatar
Thanks Jeff for the reply, The only one I see has fiberglass sleeve is that the one? When I talked to Don from eureka he said he was running behind and it would probably be three to five weeks to get the kit. I will start getting everything together to start the build. Thanks again.
Dale
Old 08-30-2013, 07:30 PM
  #499
Yes, the tube with the fiberglass sleeve is the one you want.
Old 09-02-2013, 04:24 PM
  #500
Jeff where do i get the wing adjusters and on the hacker A60 motor do you use the cage style mount or just rear mount also where did you get the carbon fiber matting thanks Steve
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
