Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Lightning Build
Old 01-13-2015, 05:32 PM
  #626
How about a copy of the plans for me too? [email protected]
Sheldon
Old 01-24-2015, 04:28 PM
  #627
Have made a start on formers and building jig, I am considering using Dualsky xm6355da motor, Are you fitting the motor directly to F1 or does it need additional support as in using a cross mount at the front. ??
[h=1][/h]
Old 01-25-2015, 06:54 AM
  #628
Viper Driver's Avatar
I am running a Hacker in runner on mine, so it mounts directly to F1. If you want to rear mount your motor, there is a former on the plans labeled "Plett F2" that can be used as the firewall. There is no additional reinforcement required.
Jeff
Old 01-25-2015, 08:28 AM
  #629
Thanks Jeff, its front mounted, just wanted to know if you can mount motors directly onto F1 without any other reinforcement
Old 02-05-2015, 07:04 AM
  #630
Jeff
Could I bother you for a set of Plans?? Would like to buildthis plane.
[email protected]
John
Old 02-09-2015, 02:31 PM
  #631
Will put more on later, just wanted to say i am really impressed with how this is going together
Old 02-09-2015, 04:10 PM
  #632
You are certainly making quick work of it!
Old 02-19-2015, 04:18 PM
  #633
I`m getting closer to the decision of glassing or film covering, never glassed before, so newbie question - is 18g cloth too fine is 45g better, will probably be using poly C once sealed, although thats still not decided....
Old 02-19-2015, 05:08 PM
  #634
I would use the 18 gram. The glass is only to provide a hard surface to paint. Go as light as you can.
Old 02-20-2015, 12:20 PM
  #635
Jeff, could you use just Z-Poxy finishing resin on the bare wood without the cloth to keep it light?
Sheldon
Old 02-20-2015, 07:10 PM
  #636
You could finish with resin on the bare wood, but it has very little ding resistance. I finished an airplane with this method back in the day and it did not hold up very well. I recommend using the lightest cloth you can find.
Old 02-21-2015, 03:22 PM
  #637
OK, sounds good. I will probably try 1/2 ounce glass cloth to cover with.
Sheldon
Old 03-11-2015, 07:47 PM
  #638
Hi Jeff,
Thanks for chatting with me a couple weeks ago in Apache Junction and I enjoyed watching you fly. I guess its time to get some official plans and try this build! My e-mail for this is [email protected] Thanks
John
Old 04-13-2015, 11:03 AM
  #639
Almost there, just built it up for CG check to find out where batteries will go - here are a few photos, mainly any differences to whats been done before
power will be from Turnigy G160 and YEP 120A ESC
canopy has 2 dowels at front, front is CF covered ply and studs on each side at rear
stab and wings are built up
Elevator servo and rudder servo are both under canopy
Have not fitted adjustable incidence fittings due to availability and not proficient enough to notice a difference
Fuz, stab , wings ( all of it ) are all glass clothed with 25g cloth and polyester resin then spray painted
when checking CG looks like batteries (2x 5 cell 5000mah) will need to go forward of undercarriage, there will be a separate power supply fitted for RX
I dont do competitions thats mainly why i glassed all of it as i have no weight limit to stick to and would rather have it more ding resistant, hope it flies as good as it looks , wont be long now....
ID:	2088683   Click image for larger version
ID:	2088684   Click image for larger version
ID:	2088685   Click image for larger version
ID:	2088686   Click image for larger version
ID:	2088687   Click image for larger version
Old 04-15-2015, 03:23 AM
  #640
Very nice work! Good luck on the maiden.
Jeff
Old 04-15-2015, 04:50 AM
  #641
Hi jeff
could you send me again the plans?
my mail is: [email protected]
Old 04-15-2015, 06:11 AM
  #642
Hello Jeff,
I would really appreciate a copy of your Lightning F3A plans. I have been searching for a balsa/ply design and found this thread and your design looks fantastic.
Thank you for your generosity in sharing this design. Email: [email protected]
Ken
Old 04-15-2015, 08:11 AM
  #643
Jeff
Thanks Jeff. will let you all know, if you are wondering how i can build so quick unfortunately had to finish work early, this is probably the quickest this plane has been built.
Old 04-15-2015, 04:41 PM
  #644
Thumbs up Plan
Hi Jeff
I would also like a copy of the plan set.
My email address is :
[email protected]
Thanks in advance.
Geison Cologni
Old 04-16-2015, 04:04 AM
  #645
Vilelas, Ken, and Geison,
The plans should be in your email.
Jeff
Old 04-19-2015, 07:14 AM
  #646
Jeff....I built "Plett F2" for an outrunner and had to come up with a way to remove the motor from the rear (inside). My "Plett F2" is 1/8 aircraft ply on the inside and 1/8 lite ply in front (with blind nuts).
I'm new to electrics and have never seen a motor mounted like this before; question is....Will this work?
If anyone has tried this with or without success please chime in.
Also; Thanks for the plans Jeff. Larry
ID:	2090145   Click image for larger version
Old 04-20-2015, 04:35 AM
  #647
Larry,
I have never mounted a motor in that manner, but I don't see why it won't work.
Jeff
Old 04-20-2015, 07:13 AM
  #648
Larry/Jeff, I use to do it that way for a few planes when I was running an AXI motor, never had an issue.
Dave Snow
ID:	2090457   Click image for larger version
ID:	2090458   Click image for larger version
Old 04-20-2015, 11:35 AM
  #649
Thanks for the quick reply Jeff and Dave; I'm going to laminate "Plett F2" with C/F cloth if it ever gets here. (slow boat from China)
Really like your mount Dave....looks super strong....Oh by the way....it was your thread on building a pattern wing and stab that got this project going.....good stuff.
Thanks Larry
Old 04-21-2015, 08:28 AM
  #650
Thank you Jeff, the design is perfect.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
