Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Lightning Build
Old 01-19-2011, 12:34 PM
  #51
Mastertech
My Feedback: (31)
Mastertech's Avatar
Default RE: Lightning Build
I still object to you using the word "Work" when you're flying F-16's for a living.
Old 01-19-2011, 01:25 PM
  #52
Doug Cronkhite
My Feedback: (34)
ORIGINAL: Mastertech
I still object to you using the word ''Work'' when you're flying F-16's for a living.
+1
Old 01-19-2011, 02:12 PM
  #53
Viper Driver
Viper Driver's Avatar
In my time away from "WORK" I managed some progress. Here, the lower stringers are installed. Also, a picture from nose on to show the curves a bit.
Next I will be doing some wetting and bending of balsa to fit the bottom.
ID:	1550154   Click image for larger version
ID:	1550155   Click image for larger version
ID:	1550156   Click image for larger version
Old 01-19-2011, 08:20 PM
  #54
Rendegade
Wow Jeff that's amazing.
Have you got plans for that?
Old 01-19-2011, 11:01 PM
  #55
Alex Voicu
Very nice work and the plane looks great!
I've been looking at this thread for a while and learned a few tricks here.
Thanks.
Old 01-21-2011, 02:46 AM
  #56
Viper Driver
Rendegade, check your PM.
Alex, thank you for the complement. You know what goes into one of these first hand.
Old 01-23-2011, 10:52 PM
  #57
alawel
Nice work Jeff. Keep the pics and updates coming. I look forward to seeing the final product.
How have you been? It's been a long time since we conversed.
Alan Wellentin
Old 01-24-2011, 05:47 PM
  #58
Viper Driver
Alan,
Great to hear from you. Don't hear much out of the old D8 crew these days. I would love to get back out there for a contest one of these days. The old days at the EAC contest were great! Keep checking in on the progress.
Jeff
Old 01-24-2011, 05:49 PM
  #59
Viper Driver
My solution for light weight servo wire conduit.
Old 01-24-2011, 05:56 PM
  #60
Viper Driver
I added a small piece to make the existing sheeting straight down the length of the fuselage to ease the difficult job of sheeting the bottom.
ID:	1552513   Click image for larger version
ID:	1552514   Click image for larger version
ID:	1552515   Click image for larger version
Old 01-25-2011, 06:19 PM
  #61
flyintexan
flyintexan's Avatar
Beautiful work Jeff.
-mark
Old 01-29-2011, 08:02 AM
  #62
Viper Driver
Thanks Mark. Still waiting to see your new bird.
Old 01-29-2011, 08:18 AM
  #63
Viper Driver
Now, on to the task of sheeting the bottom of the fuselage. This is more complicated that sheeting the top as the curves are more complex. In order to make it manageable, I am sheeting it in four sections. I don't have a good shape pre-mold like I did for the turtle deck sheeting, so it is all done on the fuselage. To keep it from getting waves, I only wet the inside of the wood, and I use balsa sticks pinned along the edges to keep them straight. When I tape the sheets to the fuselage, I only wrap it around where the formers are to prevent waves. I shape the edges of the wood prior to wetting, much easier to sand!
Here are pictures of the first two sections on the fuselage for molding, and after they dried and were removed.
ID:	1555048   Click image for larger version
Old 01-29-2011, 09:03 AM
  #64
Bill Carder
Looking good Jeff, did I tell you Alan is planning a pattern come back!
Old 01-30-2011, 07:06 AM
  #65
Viper Driver
Now that the first sections are formed, it is time to glue them on.
Here is a little trick with Gorilla Glue that I can't believe I didn't think of earlier. I used a syringe for glue for application which made it much easier than trying to use the bottle and sticks to spread the glue. I was able to use much less glue as I could apply it exactly where I wanted it. The syringe cleaned up with alcohol so I can re-use it.
I placed the seam along one of the stringers to help keep the edge of the sheeting straight.
ID:	1555722   Click image for larger version
Old 01-30-2011, 08:50 AM
  #66
Anthony-RCU
Anthony-RCU's Avatar
Hi Jeff,
Great work! Good to see getting back to r/c. How do you clean the syringe? I have tried that with some nyrod and made a mess.
Old 01-30-2011, 09:32 AM
  #67
Viper Driver
Anthony,
When I finished gluing, I squeezed as much glue out of the syringe as I could. Then I filled a bottle cap with denatured alcohol and filled and evacuated the syringe multiple times, which got most of it. To get the gunk out of the tip, I used a scrap of 1/8" square balsa stick, with a slightly sharpend tip. I stuck it through the back of the syringe and twisted it to bring out the remaining glue. Then I swished more clean alcohol through it. That left it clean enough for further use.
Old 02-05-2011, 04:24 PM
  #68
Viper Driver
Section three and four of the bottom sheeting are molded in the same manner as the first two. Balsa holds shape very well once it is dry. Once I removed the dry sections from the fuselage, I trimmed the edges to make nice seams. This is difficult as prior to having the sheeting glued on, the stringers and formers have a bit of flex. As you try to hold the parts into their final position to test the fit, you distort the structure with the pressure of holding them in place. It may look beautiful has you hold everything together, but when you take your hand away, everthing springs back into place and your seams open up. This is exactly why I keep large tubs of filler on hand.
Electrical tape was not required at the balsa sticks I used to hold the edges down while gluing are covered with a layer of clear packing tape. Easy mold release! The syringe technique also made for much cleaner seams.
ID:	1559099   Click image for larger version
Old 02-12-2011, 06:07 AM
  #69
Viper Driver
I have finally cleared out a mountain of blue painter's tape in my garage to reveal a 99% complete fuselage. The only steps remaining are to install the wing and stab sockets, and then sand to final shape. Also, I left the sheeting off of the bottom of the subfin area to allow access to the stab socket. Once the socket is glued in, that area will be sheeted. Right now, the fuselage weighs in at 20.8 oz. For comparison, the prototype weighed 28 oz at the same stage. Now, on to wings and stab.
ID:	1562165   Click image for larger version
ID:	1562166   Click image for larger version
Old 02-12-2011, 06:30 AM
  #70
tschmidt
Looks fantastic Jeff! Your a professional "balsa bender" keep up the good work!!
Todd
Old 02-12-2011, 02:17 PM
  #71
rcpattern
My Feedback: (45)
Awesome work Jeff!!!
Arch
Old 02-12-2011, 06:40 PM
  #72
Viper Driver
Todd & Arch,
Thank you for the good words. I have put in quite a few hours in the last few days, making good progress. I made it out flying today as well...have to remember how to fly too!
Jeff
Old 02-12-2011, 10:15 PM
  #73
RC_Pattern_Flyer
RC_Pattern_Flyer's Avatar
Take your time remembering unless you are going to fly FAI
Jeff,
I remember the masters finals a few years ago, it wont take you long to return to that form!
Hope to see you are the field,
Chuck
Old 02-18-2011, 04:08 PM
  #74
Viper Driver
Chuck,
Good to hear from you! I miss the good old days of D6 post flying beverages. Glad to see you have one of Mark's Harmony kits, looks like a great plane.
Old 02-18-2011, 04:30 PM
  #75
Viper Driver
On to the wings. They are more or less conventional foam and balsa wings. I do use some strips of carbon fiber for reinforcement. I had the cores cut by Mark Hunt, Insight RC. The unique thing about the way Mark does wings and stabs is his "honeycomb" method. He drills a grid of 1/4" holes rather than the traditional square pattern. I use a 1/8" lightply rib at the end of the wing socket. I also cut the holes for the aileron servos and install balsa boxes prior to sheeting. I made a tool out of 1/16" wire to cut the hole for the aileron servo leads. It is a simple loop that plugs into my soldering gun.
ID:	1566065   Click image for larger version
ID:	1566066   Click image for larger version
ID:	1566067   Click image for larger version
