Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Where to find nylon wing-half securing nuts?
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 07-06-2011, 04:57 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Default Where to find nylon wing-half securing nuts?
I have been searching for 1/4" nylon nuts somewhat similar to the pictured over internet. Not very successful.
The nut is about 3/4" in diameter (at the base) and 1/2" in height and of UNC type thread (coarse).
One nut is used to secure one half of the wing panel on my passport.
Appreciate any tips.
Old 07-06-2011, 05:14 PM
Scar
Scar's Avatar
Default RE: Where to find nylon wing-half securing nuts?
What size? If they're ΒΌ - 20, the perfect wing nut comes with a toilet seat bolt.
Ace Hardware has a great assortment of stuff like that, might have what you picture. Flange nuts, I think they call 'em.
Good luck,
Dave Olson
Old 07-06-2011, 05:19 PM
cdodom
cdodom's Avatar
I second Ace hardware. best place for all nuts and bolts.
Old 07-09-2011, 09:29 PM
OUHOZER
Lowes Hardware or Home Depot.
But the best place for just about ANYTHING IS Mc Master-Karr.com.
H.
Old 07-10-2011, 06:37 PM
Aerobatixx
McMaster-Carr is a good place too
www.mcmaster.com
but locally a good ACE hardware or True Value will have nylon nuts. Nylon wing nuts work well for this application.
Old 07-11-2011, 04:42 AM
d_bodary
My Feedback: (85)
Grainger.com
Do a search for 2HU69 As far as i know they are only sold in a pack of a hundred. 19.98 for the 100 pieces
Old 07-11-2011, 04:52 AM
d_bodary
My Feedback: (85)
Correction you can also get a ten pack
Search for a 10 pack 4AGK6 is the ten pack $2.89
Search for a 100 pack 2HU69 is the hundred pack $19.98
Old 07-12-2011, 02:51 AM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Thanks a lot all for the tips.
I went with the one available at McMASTER-CARR. it is called "nylatron round kurnled thumb nu"t with product ID 93995A360. 1/4-20, 3/4 head diameter, 1/2" overall height.
The spec matches my existing nuts quite well. The length of the section with thread (the height) is about 1/2 inch. Since the thread is coarse, I want the thread section has enough threads to avoid any chance of backout.
At Lowe's, I found nylon wing nuts and alum hex nuts. Either type is light and has a much shorter height than 1/2". Looks like two are needed per wing panel.
The one sold by granger.com probably has the shorter height as well. otherwise, it is a good fit.
Thanks again.
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
