Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Nuance
Old 05-17-2012, 03:16 PM
  #226
serious power
Default RE: Nuance
ORIGINAL: rcpattern
ORIGINAL: mups53
ORIGINAL: rcpattern
I have been flying the ''company'' plane now for a couple of weeks and am really liking it. So much so that I picked up my own on Friday. I'm very happy with the plane, and will be putting a Neu motor in the nose. The Pletty is nice, but once you have flown a Neu, it is hard to change. There is a ''feel'' on the bottom end that just isn't there with anything else. I've played with the throttle curves and such and have the Pletty close, but its just quite the same. I think the Pletty would be awesome, if you hadn't owned a Neu before. I really like the presentation of the plane. It definitely flies slower than my Winds, which isn't a bad thing. So far, I'm very pleased with it and I'm getting more and more comfortable every day.
Arch
Interesting observation Arch. That's exactly what Dave Snow reports. Having never ran a Neu motor I'm ignorant as to the difference.
I would however point to an inordinate amount of breakdowns and issues with maintainence on the Neu motors. They have a lot of them around here and I've seen a lot of failures. I've also seen a lot of guys puff packs using Neu motors. Based on that I'm reluctant to try one. Mike
I have been fortunate with mine apparently. I have had issues with the fan coming loose, but with the new style case, its an easy one time fix yourself. Other than that, mine have been bullet proof. Greasing them is not very difficult and only takes about 20 minutes. 10 of that is spent getting Marquette spinners off...lol. I have followed Dave Lockhart's recommendations with greasing and have been very happy with the results. I will agree on puffing packs. They do not like the cheaper packs apparently, but I haven't had any issues with either Thunder Power of Flight Power packs.
Arch
Hi Arch,
Joking aside, you're right about the 10 mins for the Marquette spinners.
I cured it by replacing the HS steel screws with stainless ones. They stay there with just a light tightening and do not get stiff/fused at all.
A little bling as well.
Brian
Old 05-18-2012, 04:01 AM
  #227
rcpattern
My Feedback: (45)
Default RE: Nuance
Brian,
Great idea. I didn't mind them when they first came out and had normal "allen" head screws. You had to use the right wrench or you would strip them. That is a great idea. I will try to locate some as that will help immensely.
Arch
Old 06-04-2012, 04:14 AM
  #228
rcpattern
My Feedback: (45)
Default RE: Nuance
I was able to get mine finished up over the weekend. Mine is the teal one. I wasn't a fan of the stock graphics, so my wife and I changed them. Didn't realize that the ones on the fuse were in the clear coat, or they put them on wet. I was able to get them off, but then had to sand the area. Turned out nice though I think. I put about 10 flights on it this weekend and am very happy. Need to do some ultra fine tuning still, but need a really calm evening. Sorry, for the extra picture.
Set up is:
Neu F3A
Castle ICE2 80HV
Falcon 20.5X14.5 lite
Ailerons: Futaba BLS-551's
Elevator: Futaba BLS-153's
Rudder: Futaba BLS 352
Tech Aero Dual Reguator
10#9oz with my heaviest packs.
Arch
ID:	1768912   Click image for larger version
ID:	1768913   Click image for larger version
Old 06-04-2012, 06:21 AM
  #229
Louiedajew1138
Default RE: Nuance
Looks stellar mate!
Lou
Old 06-04-2012, 05:15 PM
  #230
Viper Driver
Viper Driver's Avatar
Default RE: Nuance
Arch,
Nice job on the finish! I may have to send my plane back to you for completion.
How does it fly compared to the Wind?
Old 06-04-2012, 05:43 PM
  #231
Dave Harmon
Default RE: Nuance
Arch.....
It looks great!
The graphics change makes a significant improvement on an already pretty good looking airplane.
Good eye!
Old 06-06-2012, 06:27 AM
  #232
rcpattern
My Feedback: (45)
Default RE: Nuance
Jeff,
The planes both fly awesome. The pink one, which is Chris Moon's has the Pletty in it, and the teal one, which is mine has the Neu in the nose. I'm still tweaking the teal, but I love the braking of the Neu setup, much better than the Pletty. I also really like the bottom end torque of the Neu, more so because I am used to it, than it being better. Both planes fly awesome and I'm getting more comfortable every day. The biggest difference I have noticed with the Nuance, as opposed to the Wind, is that the Nuance is much happier at slower speeds. The Wind can be flown slower, but it requires more work, whereas the Nuance is very happy slower. I have heard several comments regarding my presentation from people I respect, such as Dave Guerin and Tom Miller on how much better the presentation is with the Nuance. Both planes fly great, but the Nuance has forced me to fly a little slower and closer, which isn't a bad thing. More than anything though, I just wanted something different.
Arch
Old 06-06-2012, 06:31 AM
  #233
rcpattern
My Feedback: (45)
Default RE: Nuance
ORIGINAL: Dave Harmon
Arch.....
It looks great!
Good eye!
Thanks Dave. My wife and I have had a vinyl cutter for years and I was already doing all of my own stuff. However, I finally sat down and really played with the settings to get it perfect and now that it is, it allows me to cut a lot more fonts of even smaller size and such, which really brings out some detail stuff. Fortunately, I had some really cool colors and such that matched. Attached is a picture that includes the new graphics on the pink one. I am very happy with how they turned out. I think the metallic pink, outlined with the silver really stands out.
Arch
ID:	1769742   Click image for larger version
Old 06-06-2012, 07:13 AM
  #234
Dave Harmon
Default RE: Nuance
ORIGINAL: rcpattern
Arch.....
It looks great!
Good eye!
Arch
Arch.....all I can say is WOW....I like the pink even more than the teal!
Now all I have to do is finish my pink Nuance and get after it.....I doubt it will look as good as yours though!
Super job....congrats.
Old 06-06-2012, 07:53 PM
  #235
patternflyer1
patternflyer1's Avatar
Default RE: Nuance
Archie,
I am surprised you need more braking in the Nuance than the Pletty.. I am told mine has a very constant speed and that the downlines are very slow with the Plett. Funny though, I was just talking to Jon Carter about liking the throttle response of the Hacker inrunners better than the Pletty. It's more YS like. I may try a 14XL again if I can ever afford another Nuance.. Hard to beat the silly power I have with the Plett though. I really love this plane! It's made flying much more fun for me.
C
Old 06-07-2012, 01:57 AM
  #236
rcpattern
My Feedback: (45)
Default RE: Nuance
Chris
Its not really the power, it is the brake setup. I think the Neu has a little smoother braking action. Not really more. I am also fairly certain that a lot of it has to do with having flown the Neu for a couple of years. The Pletty is awesome, but I am still learning it, whereas the Neu is something I am completely confortable with.
Arch
Old 06-07-2012, 01:59 AM
  #237
rcpattern
My Feedback: (45)
Default RE: Nuance
ORIGINAL: rcpattern
Arch.....
It looks great!
Good eye!
Arch
Thanks Dave. We did nothing special, except change the graphics. Let me know if you want any cut. I have plenty of that metallic pink vinly. We can easily cut you anything you want.
Arch
Old 06-07-2012, 04:49 AM
  #238
mups53
My Feedback: (41)
Default RE: Nuance
ORIGINAL: patternflyer1
Archie,
C
Ditto that whole statement Chris. Except the Hacker part. Mine has amazingly slow downlines and consistent speed. Gezz I love this plane!!!! No kiddin it's really special! Mike
Old 06-07-2012, 04:59 AM
  #239
rcpattern
My Feedback: (45)
Default RE: Nuance
Part of my issue is that the pink one has Chris' YGE controller in it, and I don't have the programmer for it, so I haven't been able to play with the brake. When I had my Castle in it, I had it where I was happy, but I need to work on the YGE controller to get it to the same point. The planes both fly amazing though,
Arch
Old 06-07-2012, 06:04 AM
  #240
underdw
underdw's Avatar
Default RE: Nuance
You guys put me over the top last night with your recent comments!
I finally was able to push the "checkout" button!
Is there a list of included hardware?
Dan
Old 06-07-2012, 06:37 AM
  #241
rcpattern
My Feedback: (45)
Default RE: Nuance
Dan,
It comes with the standard hardware. The only things I really used were the control horns, and all of the stuff they sent for the landing gear. The pushrods they include use a z-bend on them, which I didn't want to use. They would've probably been fine, but I didn't use them. The wheels are nice, and I used those. I added wing adjusters, and used the Gator R/C battery tray from Chris. It doesn't include anything to use for radio gear/ESC trays and such, so you'll need that as well. Very straight forward build, and there is a link to instructions earlier in this thread, as nothing comes with the kit, but you really don't need them.
Arch
Old 06-07-2012, 06:48 AM
  #242
Dave Harmon
Default RE: Nuance
ORIGINAL: rcpattern
Dan,
Arch
Dan....I can underscore what Arch just said....
For linkage I used SEcraft aluminum servo arms, H9 Prolink pushrods and H9 4-40/2mm ball links.
Normally I dont use ball links on an airplane like this with a plastic servo arm.....the aluminum arms prevent arm twisting.
I also used the kit horns...worked very well.
I didn't use their hinges either.
I used Great Planes CA hinge. I had to re-cut the slots because they were a bit too tight but in the same location.
Make sure the original slot is on the center line.
The hatch latch was poorly done on my airplane and is unacceptable to me so I'll replace that too with a 'Best' latch.
Old 06-07-2012, 10:30 AM
  #243
underdw
underdw's Avatar
Default RE: Nuance
Thanks guys!
Old 06-11-2012, 05:40 PM
  #244
rcpattern
My Feedback: (45)
Default RE: Nuance
Pair of Nuances with the new graphics done. My wife Tara with me.
Arch
Old 06-12-2012, 10:03 AM
  #245
Zi-Chun Lin
Default RE: Nuance
Some funny pic and vedio of my Nuance.
We has National selection for 2012 Asia Cup last weekend.
Here was the vedio of my Nuance flying in competition!!
Nuance was easy for F-13......
http://www.youtube.com/watch?v=go4V7...1&feature=plcp
Old 06-15-2012, 02:10 PM
  #246
TonyF
My Feedback: (92)
Default RE: Nuance
Here's some pics of my Nuance with the Contra Drive installed.
I cut the nose back to take out the right thrust and increase the spinner diameter to match the larger Contra diameter. It's not perfect but I think it looks OK.
ID:	1772324   Click image for larger version
ID:	1772325   Click image for larger version
Old 06-15-2012, 02:15 PM
  #247
TonyF
My Feedback: (92)
Default RE: Nuance
Here's some pics of the installation.
I'm using a Neu motor, a Castle Ice 80HV, JR 9411HV servos on ailerons, JR 3711HV servos on elevators and a JR 8911HV on rudder. A Spektrum AR7610 RX and a TP 730 2S pack for power. No regulator.
The Contra is mounted using the front carbon plate that comes with the unit that has been shaped to fit the Nuance. I then used the grommets from a Budd mount and then the rear support that comes with the Contra. As mentioned, zero side thrust but I stayed with the up/down thrust built into the nose of the fuse.
ID:	1772327   Click image for larger version
ID:	1772328   Click image for larger version
ID:	1772329   Click image for larger version
Old 06-15-2012, 02:21 PM
  #248
TonyF
My Feedback: (92)
Default RE: Nuance
I got 9 flights on it today. It's starting out very good. I'm not sure if I'll have to add the stab fences I put on the Onas as this is feeling very good so far. I have a lot of playing around to do, but I think it's going to be very good.
I have no idea what the actual incidence settings are, as I used the holes that were in the fuse for initial alignment and installed adjusters. The first few flights were mostly used to adjust the roll trim out with the adjusters. The stab is in where it was built. Right now there is very little mixing in it and since I'm still playing with CG and incidence there's no reason to say what I'm using now. The model is going straight up though so things are pretty close. I prefer a forward CG so I started with the balance just slightly behind the center of the wing tube. Most of my flights today were at that CG but later I did move it back. There was something about that CG I did not like but only more flights will get it right.
Overall, I'm very impressed. Can't wait to get things optimized to really see what she will do!
BTW, props used are not what I will be using later. I just threw them on for the first flights. I'm not even sure what ratio is in the unit now. Tonight I'm going to be putting the set-up I'm using in the Onas in to this model. I also need to baffle the motor as it's running a bit warmer then I like.
ID:	1772331   Click image for larger version
ID:	1772332   Click image for larger version
ID:	1772333   Click image for larger version
Old 06-15-2012, 03:04 PM
  #249
2Sunny
Default RE: Nuance
ORIGINAL: Zi-Chun Lin
Awesome Flying Zi!
So is the guy in the picture trying to go for a ride
It is great to see F3A flyers from around the world coming to RCU. . . . Thanks for sharing!
ORIGINAL: TonyF
Tony,
I'm definitely not the authority hear, but I do know there was some discussion at last weekends contest in VA about the CG having been way too aft for Arch's liking initially, and he ended up moving his batteries pretty far forward from their starting point. Anyways, your plane and setup look way cool, and I can't wait to hear more about your results!
Joe
Old 06-15-2012, 04:16 PM
  #250
TonyF
My Feedback: (92)
Default RE: Nuance
Hi Joe, my packs have already been installed further forward. The info sheet on the model shows the packs behind the LG mount. Mine are over it. I just didn't think I would like the CG that far back.
