Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Nuance
Old 12-17-2012, 06:32 AM
  #501
underdw
underdw's Avatar
Default RE: Nuance
Hey Chris,
Where'd you get the honeycomb material? Prior postings in various threads have pointed to source(s) with CF or fiberglass layers. I haven't spotted the stuff like you use.
Thanks for your postings on Episode and Nuance.
Dan
Old 12-17-2012, 06:49 AM
  #502
ram_z
ram_z's Avatar
Default RE: Nuance
http://www.acpsales.com/Sandwich-Panels.html
This where I buy this stuff...
Old 12-17-2012, 07:24 AM
  #503
patternflyer1
patternflyer1's Avatar
Default RE: Nuance
I will double check that after work. thanks.
4595 is light. I agree. shocked me. several who picked if up noticed how light it was. I believe I used the f3aunlimited 5000 to weigh. could have been the f3au 4500s though.
chris
Old 12-17-2012, 07:30 AM
  #504
patternflyer1
Default RE: Nuance
aerospace composites here in cali. they are 30 minutes from where I live and on my way to work. makes it convenient for me. the stuff I used is a stronger heavier honeycomb. I knew mounting the elevator servo on it, it would need to be stronger. I also added a carbon rod to make it not move. I have seen honeycomb flex cause trim issues.
chris
Old 12-17-2012, 09:57 AM
  #505
mups53
My Feedback: (41)
Default RE: Nuance
Is the material used to make the trays this??
http://www.acpsales.com/OnlineStore.php?cat=426
Thanks, Mike
Old 12-17-2012, 10:23 AM
  #506
Portlandflyer
Default RE: Nuance
Mike,
No that's the stuff in the center of the panel. This is the one you want that is glassed on both sides.
http://www.acpsales.com/OnlineStore.php?cat=5084
Pat
Old 12-17-2012, 10:28 AM
  #507
mups53
My Feedback: (41)
Default RE: Nuance
Oh I missed asking what I was thinking.
Is the stuff I posted the material for making the panels at home?
I want to get a vacuum bagging system on do it myself. Thanks, Pat.
Mike
Old 12-17-2012, 10:37 AM
  #508
ram_z
ram_z's Avatar
Default RE: Nuance
ORIGINAL: mups53
Thanks, Mike
[link=http://www.acpsales.com/OnlineStore.php?cat=5084]http://www.acpsales.com/OnlineStore.php?cat=5084[/link]
This is the one I use in my Nuance and will use also in the next project, the Episode.
I hope it helps.
Ram
ID:	1831148   Click image for larger version
ID:	1831149   Click image for larger version
Old 12-17-2012, 10:41 AM
  #509
Portlandflyer
Default RE: Nuance
Mike,
I thiught that might be what you were asking. And yes, it is the stuff to make your own.
Pat
Old 12-17-2012, 10:44 AM
  #510
ram_z
ram_z's Avatar
Default RE: Nuance
ORIGINAL: patternflyer1
chris
My Nuance is 4650g with Rhino 4900, RS carbon prop, plastic spinner and I also changed the original landing gear to RS. (less swap)
I think that under this weight it is too light to handle strong wind.
Did you face any problems with this setup in strong wind?
Ram
Old 12-17-2012, 11:29 AM
  #511
patternflyer1
Default RE: Nuance
with cg forward I havent noticed wind issues different than a heavier plane.
chris
Old 12-17-2012, 09:13 PM
  #512
MTK
Default RE: Nuance
ORIGINAL: mups53
Mike
Mike, a suggestion...
For smaller jobs, a food saver vacuum packer works great. WalMart carries some systems at reasonable prices.How I make all of my firewalls and canopy bay floors, and soft mount facings
Asingle layer of 3K carbon cloth on each side of cross grained balsa for firewalls of gas engines as large as DLE55 isplenty strong enough but engine must be soft mounted....
A single layer of that carbon cloth on each side of 1/8"Nomex honeycomb should be all you need for e stuff in the motor area. Remember to always back up the holes with a piece of carbon tubing to keep the laminate from crushing
Old 12-18-2012, 06:30 AM
  #513
mwoytassek
Default RE: Nuance
Mike
Matt is right these tools work very well and will teach about vacuum bagging small parts.
http://www.ziploc.com/Products/Pages...zerSystem.aspx
Mark
ID:	1831468   Click image for larger version
Old 12-18-2012, 06:42 AM
  #514
Flyer88
Default RE: Nuance
[quote]ORIGINAL: mwoytassek
Mike
You guys have been watching to much Martha Stewart !
Getting all crafty....
Old 12-18-2012, 06:53 AM
  #515
MTK
Default RE: Nuance
[quote]ORIGINAL: Flyer88
Mike
Be veweey veweey quiet....You might learn somethin'
God forbid!!
Old 12-18-2012, 09:35 AM
  #516
Bubblehead575
Default RE: Nuance
Rookie here again
2 questions
Why are you using vacuum to laminate CF to Ply or sandwhich material, what is the benefit over just laying the cloth on the material and soaking the cloth
And how are you doing the vacuum bagging. What is the process, I have never done it
Bill
Old 12-18-2012, 10:05 AM
  #517
robert
Default RE: Nuance
Ola Fremming has some great articles on making various bits and pieces for F3A planes, these 2 might be of use.
http://www.ofremmi.info/HowTo/Honeco...omb_panels.htm
http://www.ofremmi.info/HowTo/Vacuumbag/VacuumBag.htm
Old 12-18-2012, 10:07 AM
  #518
MTK
Default RE: Nuance
ORIGINAL: Bubblehead575
Rookie here again
2 questions
Bill
Vacuum does several things.
Primarily, it exposes the joint toreasonably high clamping force. Typical vacuum in this app is around 22" Hg or around 10 pounds per square inch clamping force.
Clamps with a very even force around the whole area of the part. Not that easy a thing to do with other methods
It increases the mass ratio of carbon (or other) to epoxy. For composites, it improves part stiffness and reduces weight (less epoxy is required)
It removes air bubbles from the epoxy which were placed there when mixing. In continuous vacuum systems (not the subject of these last few posts), vacuum removes off-gas given off by the polymerization reaction and produces a stronger part. For some military apps, this is a must; again, it doesn't matter in our app
Rookie Bill, ask whatever questions you have in PM's please, or better yet, directly to email. I've highjacked this thread enough. Off to other things.....
Old 12-18-2012, 10:52 AM
  #519
jgg215
Default RE: Nuance
Matt,
Correct me if I'm wrong but I can't see doing a honeycomb sheet using cloth, epoxy and the  open structure honeycomb and then hitting it with a vacuum. Mike was originally asking about making his own honeycomb sheets. I think most of the honeycomb laminate is done using pre-preg and no vacuum in which case it would better to buy those sheets pre-made.
John
Old 12-18-2012, 11:36 AM
  #520
MTK
Default RE: Nuance
ORIGINAL: jgg215
Matt,
John
Of course you can. It's simple!There is one other element of course so please think about it and you will figure it out
I don't use prepreg; just too expensive for my tastes. And I don't have a fancy oven to followthe thermalprotocol.
BTW- the last honeycomb composite panel stock I made, used 1/16" honeycomb stock. I used 2 layers of it sandwiching 1.4 oz cloth between the honeycomb and 2 oz cloth on each side of the honeycomb. Produced some very light canopy bay flooring and rudder servo mount. This is being used in my DLE55 powered Delta. I will post photos at some point in my Derivative thread....
Old 12-18-2012, 01:27 PM
  #521
VerneK
Default RE: Nuance
I bought a sheet of the ACP glass/honeycomb and found it to be nearly twice as heavy as some glass/honeycomb I had left over from a Smaragd I built a few years back. I also have some glass/honeycomb I made myself and it's also about half the weight of the APC stuff made with pre-preg, though not as nice as the Smaragd stuff. My conclusion which may be inaccurate is that pre-preg is heavy since the honycomb should weigh the same.
Verne
ORIGINAL: jgg215
Matt,
John
Old 12-18-2012, 02:19 PM
  #522
Rune
Default RE: Nuance
hi
I have used 2 layers off 1,5mm balsa layed in "cross" with 50gr/m2 carbon on both sides all glued with thin epoxy cured between some thick mylar sheets we have at work and with some heavy weight on .
Stiff and pretty light , used this for servo trays and battery plates
Old 12-18-2012, 02:34 PM
  #523
cmoulder
Default RE: Nuance
Verne
Just curious, why use the glass honeycomb and not the CF, which is incredibly light?
I have seen this elsewhere but don't understand what benefits the glass sandwich offers that CF doesn't. (Besides CF being some nasty stuff to get in your lungs...)
Old 12-18-2012, 07:15 PM
  #524
VerneK
Default RE: Nuance
I use the glass/honeycomb primarily for my rudder tray which also holds the Rx, Digiswitch, and Rx battery. My main concern on glass versus carbon is the antennas coming off the Rx. It might not matter, but I feel better keeping those away from carbon. I use carbon/nomex for my motor battery tray.
Verne
Old 12-20-2012, 06:36 AM
  #525
mups53
My Feedback: (41)
Default RE: Nuance
ORIGINAL: VerneK
Verne
What he said ditto x 2
