Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
YS To Electric conversion
Old 01-11-2012, 02:56 PM
KGSS28
Default YS To Electric conversion
Can anyone tell me about how much weight the total setup to for the YS is ? Including everything it takes to run it. I an considering a conversion ,trying to figure out what I have to play with but don't want to strip the plane to weight it all.
Old 01-11-2012, 03:49 PM
nonstoprc
My Feedback: (90)
nonstoprc's Avatar
Default RE: YS To Electric conversion
I documented my conversion of an old Sequel to electric here http://www.rcuniverse.com/forum/m_95...tm.htm#9602184.
Fort the Sequel, I have to remove extra weight from the plane to make the plane fly well and to meet the AMA 5kg rule. You have extra 115grams allowance if compete in class lower than Masters in Nats.
As a reference, the best of an electric power system one can buy has the following weight distributions
1. motor + prop adaptor: 20-21oz
2. battery: 2lb 11oz
3. prop: 1.5 - 2 oz
4. ESC: 3-4 oz
The total is 70 oz = 4.375 lb. 11 lb - 4.375lb = 6.625 lb.
That should the cap of the total weight of the plane after the removal of the YS engine, tank etc.
Old 01-12-2012, 04:32 AM
Jon Wold
Jon Wold's Avatar
Everything I removed from my 170 CDI powered Integral including throttle servo, linkages, fuel tubing weighed in at 1900 grams. Add to that the lighter props available to electric motors and you're close to 2 kg.
