Watt Meter Recommendations
I am now looking at the eagle tree e-logger V4 with the panel display which gives me further scope to be able to log flight data as well as having a watt meter. There are 2 models 100A and 150A version. Would the 100A be sufficient for F3A 10S setups or should I go for the 150A. Dont think there is much difference in weight however the resolution of measurements will reduce slightly with the 150A model.
