Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
3 blade prop for Electric ?
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 06-09-2013, 06:00 PM
kregan
kregan's Avatar
Default 3 blade prop for Electric ?
Searching the forum for prop info on the Haker A60 I see 20.5" x 14" two blade
as a good starting point. That will require me to lower my landing gear on the
Brio so I was wondering if any of you are running 3 or 4 blade props in electric?
Old 06-09-2013, 08:36 PM
apereira
apereira's Avatar
Default RE: 3 blade prop for Electric ?
Mezlik is releasing a three bladed prop designed by Wolfgang Matt wich is ultra light and very good.
Old 06-10-2013, 03:08 AM
wildwillie3
I'm running a 15.75x13-3 APC with a AXI motor in a Brio right now and it works well so far. It's a pretty heavy prop compared to a 2-blade electric one.
Bill
Old 06-10-2013, 04:59 AM
Silent-AV8R
Silent-AV8R's Avatar
I've been flying a PT Models 20x13 3-blade in my Abbra. I've got the normal weight version =92 grams. There is also a light version. F3A Unlimited sells them. I am starting to like the prop. Good constant speed. I'm using a Plettenberg Advance with it.
Old 06-10-2013, 07:06 AM
mups53
My Feedback: (41)
http://www.f3aunlimited.com/webstore...roducts_id=538
http://www.f3aunlimited.com/webstore...roducts_id=767
We have both the regular and light versions available.
The testing on a Pletty Advance and on a Proteus yielded a very favorable result. I've been told the downline brake effect is noticable.
Thanks, Mike
Old 06-11-2013, 06:02 PM
kregan
kregan's Avatar
Thank you guys, I will check them out.
Old 06-12-2013, 08:08 PM
Ryan Smith
My Feedback: (25)
I always preferred four-blade props on my YSs. I would be interested to see how one of those would perform on an electric motor.
