Jetti Spinn 99
ON, CANADA
I installed the Jetti ESC and programmed the throttle curve through the transmitter (14SG) and really like it. I then used the Jetti program box and set the throttle curve to linear and did not like the way it worked for me. The question I have is this. Since I programmed the ESC using the jetti program box, does it now not recognize the throttle curve I programmed in before using the Jetti box? If so, do I simply go back into the programmer and take out the linear setting and the ESC will now recognize my throttle curve from the transmitter again? Any help will be greatly appreciated. Thanks
Dave
Dave
ORIGINAL: david hancock
Dave
Dave
Jim O
