Questions on Hacker MasterSpin Pro 99, JR 12X, SpinBox
I am totally new to Spin ESC and SpinBox setup.
I've been using Castle until about a week ago, but found out the brand new Castle 85HV wasn't holding the rpm consistently, so swapped with MasterSpin Pro 99.
By the way, it is with Hacker A60-7S with APC 21x13.5E, and JR 12X.
Right now, I have prop ripping, so will have to change the prop before next flight. Probably will try 22x12 or something similar.
Technical data for A60-7S V2
Technical Data:
Powerrange max. 2400W (15 sec.)
Idle Current at 8,4V 1,2A
Resistance 0,026 Ohm
RPM / Volt 215 U/min-1
Weight 595g
Diameter 60 mm
Length 62 mm
Type 28-Pole
recommended Timing: 25°
Switching Frequency 8 kHz
recommended Prop APC-E 22x12 ~73A at 10S Lipo
Usually I setup idle using throttle trim. I have throttle cut enabled with value of 0. When I move the throttle trim to start motor, initial starting power is way too much (motor starts spinning and about 50% of trim) that the plane can't stay put even on tall grass. So, I have to back the trim back to about 25%.
Is there a way to start motor at same point where I want it to idle?
Current setting shown from the ESC are as below.
Temp Protection: 100 degrees Celcius
[b]Brake: Soft 30/100/1.5s
Technical Data:
Weight 595g
Diameter 60 mm
Length 62 mm
Type 28-Pole
[quote]ORIGINAL: PatternFlyer
Technical Data:
Weight 595g
Diameter 60 mm
Length 62 mm
Type 28-Pole
Switch throttle cut on. ESC should arm.
Switch throttle cut off
Will the brake is now active?
Jog throttle stick and return to idle
Fine tune the idle. You just do this once, it should be good forever after that.
Jim O
Jim O
Viktor.
After setting the end points in the ESC as stated in red above, set up the transmitter throttle curve. Full throttle should be at 2.0 milliseconds. Low throttle should be at the desired idle which will be over 1.1 msec. Set your throttle cut to something below 1.1 in order to arm the ESC.
Turn on procedure:
Connect 10s pack.
Turn on transmitter at low throttle and not in throttle cut.
Turn on receiver. ESC should not arm.
Check all other controls
When you get around to using the brake we can talk about that.
Jim O
Turn on procedure:
Connect 10s pack.
Jim O
Dave.
As far as the ESC brake settings you need to play around but I find 50% at max acceptable and I don't waste anytime delaying it.
Hope this helps.
Jim O
Victor, for flight the throttle cut must be turned off or you have no throttle control. Therefore you need an idle down switch in addition to the throttle cut if you want to turn the brake on and off and have an idle.
