BJ Craft Motor Mount Questions - ALL Airplanes
Hey all,
I'm interested in putting together a database of motor mount dimensions for all of BJ's airplanes. Ideally I'm going to make up a CAD drawing for each airplane with the motor options. Can those of you who've built airplanes of his reply here with the following info:
Motor Used
Diameter of Front or Rear plate (depending upon how it's mounted)
Diameter of mount bolts, and on what centers (distance from center of prop shaft to center of bolt)
Motor Used
Hi Doug
it won't be that easy.. If you look at post #170 on the Bi Side thread I posted my starting dimensions for the template I made. But the final firewall was shaped to fit and wasn't that exact dimension. As for mounting, the pletty Advance 30-10 uses a 40mm bolt circle with 6 4mm bolts.
It was different on the Episode since the spinner is a smaller dimension. The mount was not circular, it was sort of oval shaped at the bottom. I think I posted my basic dimensions on the Episode thread but, once again, those were starting points and not the final exact dimensions.
It might be easier if we send B.J. the exact motor dimensions so he can generate the firewall drawing from his CAD model for the fuselages. He has a model for a hard mounted Neu F3A-1. But, most people are soft mounting that motor so he would also need the Budd mount details or the Hyde mount info. The Pletty and Q80 are hard mounted so motor dimensions would suffice. I'll send him a note and see what he thinks.
