Falcon spinner w/ Plettenberg Advance
My spinner doesn't fit my motor. Does anyone else have this combo? Any issues? The spacer in the back plate is too tight for the motor shaft. Removing the spacer leaves the hole too big.
What is the shaft size? I don't recall if I measured. I assumed the backplate was sized for 8mm and 10mm, and the motor shaft is close to the 8mm size.
This is annoying.
This is annoying.
Hey Joe.....same thing here but I took a strip of 400 grit wet/dry paper with a little oil and reduced the size if the shaft a tad.
Plett puts a black finish on the shaft which must add a bit of thickness....I removed it by running the motor at a slow speed and used the paper....fits perfect....I didnt trust myself to not booger the spacer hole.
Thanks Dave, good thought. I haven't worked on the motor again since I started this thread, but this is a good reminder to check the shaft size. Since most things are sized for 8mm motors, your solution does make sense. I will consider it when I pick my poison, so to speak.
It will still be a bit tight....don't want it to be loose...but at least you can remove it if you need to without damage.
Dave
