Prop for Hacker Q80 11S
My Feedback: (23)
I bought a used De Ja Vu that has a Hacker Q80 11S.
The previous owner was running an APC 21x14 on it and I'm interested in getting a new prop. Since the APC 21x14 is no longer available, what would be another good prop to try?
I don't mind paying for a carbon prop and the replacement doesn't need to be another APC unless that is what is suggested.
Depends on the airplane / flying style to some extent. The 11S can handle anything your batteries will. On the Allure I like the Falcon 20x13-3B for smoothness, speed, and quiet until it gets really hot (low air density) - not too bad on mAh. The Mejzlik 20.5x12W provides similar performance with fewer mAh. In hot weather the Mejzlik 21x13EL works really well, a bit fast as AD improves and can use mAh. When the weather's lousy and you want more speed the Mejzlik 21x14 will get it done at the expense of batteries. Generally speaking, Mejzlik are a bigger load but quieter than similar Falcons (both work well).
