Caressa by Bryan Hebert of CK Aero
#51
I will try to get some up this week. Pretty busy here taking advantage of flyable days when they are here. Hang in there.
On another note, I am so pleased with the flying characteristics of this plane that I am going to Baton Rouge this week end to pickup a second Caressa for a backup and get my replacement chin cowl.
Sheldon
Sheldon
#52
Let me know if you have any more questions or have a better way to secure the tray. I am always willing to learn new things.
Sheldon
#53
Here are three photos that should help with your installation. As you can see I just added two pieces of 3/16-inch plywood for the legs, used epoxy to keep them secure, located where to drill through to intersect the landing gear tray, and drilled the holes. I placed the tray into the aircraft and hand drilled a starter hole to make sure I go through the landing gear support. Oversize drilled the hole in the land gear support so a 4-40 t-nut would set in fairly firmly, screwed a socket head 4-40 screw to hold the t-nut in place, and hit the t-nut with a drop of CA. Made sure the CA was fully set, removed the socket head and double checked the hole alignments. Was off just a little bit on one screw so I oversize drilled the leg hole to the next sized drill bit up and that fixed the alignment and allowed the tray to be screwed in place. Make sure you use washers on the screw head to spread the load on the tray legs and to prevent too much dimpling on the legs. You have to look close, but in one picture you can see the two 4-40 nuts on the landing gear support.
Sheldon
Sheldon
#54
I had the same issues on both my wings and there are two solutions that come to mind. 1) On the aileron bottom you can cut a small square out of the composite to size with a very sharp #11 blade. Save the composite to glue back after you add more hard point. 2) You can move the aileron into a full up position and go through the leading edge of the aileron and slide more hardpoint through there, Be careful not to stress the aileron hinge too much. The first repair was the way I did it and the second repair was done by Monte Richard, NSCRA District 6 Vice-President and it worked real well.
The hardpoints are in the dark blue area of the bottom of the aileron and the repair will not be seen readily no matter which way you do it. Attached is a couple of photos of the only flying Carresas in the US at this time. The one on the left is my electric powered, the one on the right is fuel powered. The plane in the middle is an Alchemy, Bryan's high end replacement for the Allure. All flew excellent. That is Bryan Hebert, the designer, in the middle.Sheldon
#56
If you removed the tape that prevents the elevator from moving in relation to the stabilizer use some masking tape and re-tape it to make sure the stabilizer/elevator cannot move. Then set the fuselage so the canopy rail is level to 0.0 degrees using a Wixey meter. Insert the stabilizer through the holes in the fuselage. Set up the Wixey and make small adjustments on the grub screws (top and bottom) until the Wixey reads 0.0 degrees also and the grub screws are snug. Put the other stabilizer on and do the same thing. Keep checking the left and right stabilizer and fuselage to make sure nothing shifts on you while doing the process.
One of the stabilizers already has an additional set screw on the bottom that is already tight. All you have to do is drill through the access hole on the bottom of the other stabilizer into the carbon fiber support rod and add a similar small screw to hold it all together after the adjustments have been made. Check one final time to make sure all is well and they are both equal to 0.0 degrees.
My plane is inaccessible right now loaded in the car ready to go. When I get back from flying I will set it up on the table and take some photos. Sorry I did not do that before.
Sheldon
Sheldon
#57
Here are some photos:
First up is the stabilizer with some tape to hold the elevator in place and provide some friction on the leading edge so the frame does not slide down the leading edge. Second is the Wixey with the frame checking the level of the fuselage. The third photo shows the stabilizer and elevator also at zero. I give up trying to take pictures so they show right side up!! But you can get the idea.
Sheldon
Sheldon
#58
I will try to upload some pictures of my Caressa. Checking CG with dowel between fuselage sides is new to me. However, the fuselage tends to spread apart. I made a jig with control rod that seems to work well in minimizing spread.
