Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Wing Incidence Adjusters
Old 04-05-2018, 07:59 AM
MPicou
Default Wing Incidence Adjusters
I'm installing the F3A wing incidence adjusters on a BJ Park Etude. It looks like the best way is to use them is to mount them to the holes ahead of the main wing tube (and use the supplied ones on the holes behind the main wing tube). I'm guessing I'd glue the short tube pieces to the wing and they would slide into the adjusters. Is this correct? Or should I mount the small tubes to the adjusters and have them slide into the wing. Thoughts? Could someone post a picture of the fuselage insides and the wing mating surface?
Thanks a bunch!
Old 04-08-2018, 08:36 AM
grotto2
grotto2's Avatar
That's a really good question, MPicou. I'm facing it on my latest plane, too.
I can say, however, that I used the latter method (sorta) on my last BJ plane and it's worked for years. My adjusters have 6mm pegs that stick out about 15mm from the fuselage sides to engage holes in the wing root.
Hope this helps.
Old 04-10-2018, 07:02 PM
mgosson
My Feedback: (8)
If you search around you will find a thorough build thread thread on the Etude.
Old 08-03-2018, 08:28 AM
pippy
Default Wing adjusters
whose adjusters are the silvers ones and where can they be bought?
Old 08-03-2018, 10:31 AM
ltc
From Mike at F3AUnlimited
https://www.f3aunlimited.com/gwa8mm
Old 08-03-2018, 11:11 AM
ltc
Link to previously mentioned build thread
Installing adjusters ...
http://www.rcuniverse.com/forum/12315958-post125.html
