Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
The most quiet electric 2M motor/prop?
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 05-14-2018, 12:40 AM
bem
Default The most quiet electric 2M motor/prop?
Hi,
What motor and prop(s) is in Your opinion among the most quite today for 2M planes?
I have heard at competitions some rather quite Contras and as far as I remember it was Brenner Contras V4 and V3.
Not sure about what props was in use.
Why I ask is because we got some complaints from a neighbor to our field (it is a full scale airfield by the way) that my Galactika with
Hacker Q80-14XS and Falcon V2 Electric carbon 21x14 disturb (the sound) when flying.
In my ear it is rather quiet when flying - some more sound of course when adding power at vertical up maneouvres.
I figured I would prepare some so I know what my options are regarding really quite setup, if I need to change to that.
So I have some action to suggest if it is more complaints.
Thank's
Bo
Old 05-14-2018, 01:06 AM
ltc
Are you running or have you tried a soft mount?
Ralph Schweizer makes a very nice one for the Q80
Perhaps people might be hearing fuselage resonances at certain throttle settings ?
Old 05-14-2018, 01:42 AM
bem
Hi ltc,
No I do not use a soft mount.
Could be some resonance in fuselage at som RPM's, hard to tell. I have not suspected that myself.
I will check out Ralph Schweizer homepage and see what he as for soft mount.
/Bo
Old 05-14-2018, 05:16 AM
ltc
2nd item down on this page
RSnewproducts
i believe he also sells various length soft mounts to adjust spinner distance as well
I just received an RS adjustable soft mount for the V4 Contra (will be going in a Mriya biplane)
Its a work of art when you look at it!
He does amazing work ...
Old 05-14-2018, 05:32 AM
Ekvien
I feel that Mejzlik 21x13 is the most silent prop for the Q80-14xs. But with regards to noise I did not find any electric set up with big props noisy at all, with exeptions for Hacker geared engines which are in lack of lubrication
Old 05-14-2018, 06:01 AM
bem
RSnewproducts
Hi,
Yes that is the motor mount I have in my Galactika (since 2015 but bought this carbon motor mount from F3A Lorenz).
http://www.rcuniverse.com/forum/elec...l#post12208308
I will ask RS (Ralph Schweizer) what rubber mounting solutions he has for this mount.
thanks,
Bo
Old 05-14-2018, 06:07 AM
bem
Hi Espen,
I might try that prop (I have not experimented with other props at all with my Galactika+Hacker Q80-14XS so far).
How about 3 blade prop - is it in general quiter then a 2-blade prop - anyone know?
There is a nice 3-blade prop that RS (Ralph Schweizer) sell:
RS-Page
First image, it is for Q-80-14XS (that I have) and they write that Stefan Kaiser use this 3-blade prop (but with Hacker Q80-14XS Sensitrol motor+ Sensitrol ESC).
/Bo
Old 05-14-2018, 06:24 AM
big_G
Originally Posted by bem
Hi Espen,
RS-Page
/Bo
I use a 19 X 13.5 3 blade prop that is extremely quiet, in front of a Hi Max 6330-210 Pro.
Old 05-14-2018, 09:09 AM
Bubblehead575
I use a Plettenburg Advance with the 19x13.5 Falcon 3 blade and it is very quiet.
Old 05-14-2018, 05:54 PM
Goodie_2_Shoes
Goodie_2_Shoes's Avatar
1+ For the Plettenberg Advance and Falcon 19x13.5. I was using that combo on a Krill Spark. It was nice and quiet with good downline braking, battery consumption went up by about 400 mAh but maybe I just needed to work on throttle control...
Currently using an Adverrun contra mounted on 4mm aircraft ply running Mejzlik props 22/20F 22/22R and so far it seems pretty quiet to me. However, I haven't had it tested using a decibel meter.
