B.J. Super Fantasista
#51
2M Fantasista for sale Smokin Deal Houston TX area
I am selling a Fantasista with around 60 flights on it.
Comes with the following Gear...
Scorpion F3A motor
Spare Scorpion motor
Scorpion Tribunus 130a ESC
Kings Max servos
CF 20x13
CF Spinner
Futaba 14ch 7014SB Receiver
Cloth Wing Bags
Spare Canopy (brand new)
There's over $4000 in it but I will let it go really cheap!!!! half price. I have decided to go another direction.
If interested text me, I am rarely on this site. 832 745-2572
Scorpion F3A motor
Kings Max servos
CF 20x13
CF Spinner
Cloth Wing Bags
#52
Hello Delicious J,
I am surprised by the position of the engine battery holder on your Fantasista.
Why did you position them so forward?
Did you check the centering?
On mine the batteries are positioned in the middle of the landing gear box.
best regards
Clément
best regards
Clément
#53
If I run my batteries about a half inch of the back of the tray the CG is neutral. If I run the batteries centered in the tray its a tad nose heavy. So in other words, the battery tray works for whatever CG preference one might have.
#54
Hi
I am the constructor and the pilot of the fantasistas in photos on this post, and I confirm that the CG is between 16 and 17 cm from the leading edge of the wing to the implantation.
For good centering you need the batteries in the middle of the gearbox.
Then you have to adjust according to your piloting, but this allows this position to have a good base.
Fred
Fred
#57
Hi Jean Paul,
which film brand have you used to cover the extended part of the aileron?
I am wondering whether the standard Oracover white matches the white on the Fantasista...
#64
Hi
I finally try the Fantasista without flaps.
As expected, the ailerons became slightly more sensitive.
The snap roll is a little more nervous.
In the end, for the flight it doesn't change much for me, who had never used flaps.
For the plane I gained about 120 grams ( servos, extension, control horn and various ).
The next one i'm going to just block the flaps without changing the wings.
Fred.
Fred.
