Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Weight for Sheeting a Wing
Old 11-26-2018, 06:09 AM
ben beyer
My Feedback: (23)
ben beyer's Avatar
Default Weight for Sheeting a Wing
I have a Cadence kit that I'm about to start the build on. The last time I sheeted a wing was on a 39% Dalton Extra 300 where I believe I stacked around 400 lbs. of weight on the wing panels if I remember correctly.
How much weight would be good for sheeting the wings on the Cadence when using polyurethane glue?
Old 11-26-2018, 06:39 PM
rgreen24
rgreen24's Avatar
I used 150 pounds, and it worked just fine.
Old 12-01-2018, 07:08 PM
kenh3497
kenh3497's Avatar
Vacuum bagging is an option also. You only need enough weight to make sure everything is bedded properly then the vacuum takes over. 5 inches of vacuum is all you need so you don't need a super expensive setup. I heard some will use a modified air pump for a fish tank.
Ken
