Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
The New F3AUnlimited Nuance G2 2 Meter ARF
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 10-14-2020, 04:11 PM
gene55
Default The New F3AUnlimited Nuance G2 2 Meter ARF
Is anyone planning to build the new BJ Park Nuance G2 ARF?
F3AUnlimited just received stock of them today.
"www.f3aunlimited.com/airplanes/f3a-aircraft/bj-craft-nuance-g2-arf-2m-pattern-plane"
I ordered one today.
Would like to see some build pics, since ya'll have built these type of ARFs before.
Cheers
Old 10-22-2020, 11:57 AM
dwhorn
My Feedback: (28)
Cheers
Just started my build today, Spent 3 hours yesterday reviewing the forums to get a understanding of what to and not to do.
Looks to be fairly simple build. Installing a contra drive in this bird.
Good luck with your build
Old 10-22-2020, 12:20 PM
gene55
Hi, dw
Thanks for the reply.
Just received mine today. Was amazed at the lightness of the crate. Motor and accessories in a separate package
to avoid damage to the airframe. Excellent.
Had David Snow perform the HiMax 3300 motor mount installation, as I couldn't find a sequence of clear pics as a guide.
David sent such a pic sequence so after soldering the motor connector, motor re-installation will be a snap.
Am using using the HiMax 3300 single drive arrangement with a Falcon 3-blade, 19x13.5" prop with a Kontronik
Jive Pro 120+ Pro ESC.
Already had the Jive Pro +, so I had all the necessary tools and direct knowledge to upgrade it's software and to program it.
Are you planning to use the Emcotec arming switch?
Good luck with your build, too...…..Please keep us posted.
Cheers
Old 10-23-2020, 11:07 AM
MPicou
Hi guys,
I've built about 5 planes from BJ Craft. They all build basically the same, so look for any build thread for a BJ Craft plane and that should get you through any questions.
Old 10-23-2020, 11:11 AM
gene55
I try, but the minor complaint I have is that the build threads always seem to get sidetracked by
discussions of other things and don't stick to the point at hand.
Old 10-23-2020, 11:13 AM
gene55
But, here is a question that I haven't seen an answer to:
How and what does one use to keep the long servo leads from the servos mounted under the horizontal stab
from flapping around in flight?
How does one reach back down the length of the fuselage aft section?
Old 10-23-2020, 02:37 PM
Bubblehead575
I make a cardboard tube by wrapping strips of paper bags around a broom handle. using contact cement to glue them together.
I then install it by using some 1/16th to 3/32 balsa straps that I drill a hole in for the tub, then glue them to the tube and formers at the back and front.
Then feed the servo leads through it.
Old 10-23-2020, 02:45 PM
gene55
Hi, Bill
Sounds like a good idea.
Am using 2 elevator servos and 1 rudder servo.
If, when feeding the connectors thru, I can minimize the tube diameter to lighten the weight.
Cheers
Old 12-19-2020, 02:59 PM
dwhorn
My Feedback: (28)
Installing a contra drive in my build and when i took out the right thrust I think i lost correct down thrust.
What is the correct down thrust amount. No plans to reference.
Old 12-21-2020, 06:48 AM
Bubblehead575
I have had several and they are .5 deg (1/2 deg) down. but I have had to shim some of them after install to get a straight vertical
wattsup (12-21-2020)
Old 12-21-2020, 07:07 AM
dwhorn
My Feedback: (28)
Thank you!
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
