Go Back  RCU Forums > Electric Aircraft Universe > Electric Pattern Aircraft
Reload this Page >
Most reliable ESC? Help me go shopping.
Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Old 04-18-2021, 04:51 PM
orthobird
Default Most reliable ESC? Help me go shopping.
What would be your recommendation for an ESC that is reliable?
I am using JETI for the radio.
10S system
and the motor is Advance 30 - 10 by Plettenberg
thanks
Cam
Old 04-18-2021, 05:19 PM
wattsup
If your D3 has not worked for you, perhaps the Jeti Mezon 130 12S esc would be more suitable in conjunction with your JETI Tx. I have used my Jeti Mezon 130 !2s esc with my Advance 30-10 for the last 2 years with ZERO issues. Contact Espirit Hobbies in Florida for more information or just go on their website. Hope this helped you.
Old 04-18-2021, 05:35 PM
orthobird
thank you so much. Ordering it now.
Old 04-18-2021, 05:41 PM
orthobird
there are two of them:
1.
Jeti Mezon 130 12S Brushless ESC w/Telemetry
Manufacturer Jeti Applications Heli/Airplanes/Sailplanes
Special Features Data Logging, Telemetry
Cont/Max Amp 130/300A
Cells NiMH/NiCD 6-40 cells
Cells Li-poly 2-12 cells
Voltage 5-51V
Programming JetiBox, JetiBox Profi, PC
BEC Type/Continuous /Max (A) Switching/10/15A
Max #Servos/V 7-10/5-8V
Dimensions 110mm x 36mm x 24mm
Weight 155g
2.
Jeti Mezon Lite 130 12S Brushless ESC w/Telemetry
Manufacturer Jeti
Voltage 5-51V
BEC Type/Max (A) Switching/8A
Dimensions 90mm x 37mm x 22mm
Weight 140g
Old 04-18-2021, 05:57 PM
wattsup
You want the "Lite" version. Also be sure to order the Jeti Programming Box along with it unless you can program it directly from your Jeti Tx.
Old 04-20-2021, 03:18 AM
SurferDude87
I’ve had pretty good luck with my Kontronik Jive 80 pro. Just another option.
Old 04-20-2021, 10:38 AM
Ricardo M.
I am useing Futaba MC9100 ESC and Jeti SPIN 99 Pro Opto with Plettenberg Advanced 30-10. No complains on both.
Old 04-21-2021, 06:27 AM
checho4
I use two:
d3 and the jeti spin opto 99 since 2013
both works perfect!
Old 04-23-2021, 08:36 AM
ron_van_sommeren
ron_van_sommeren's Avatar
APD controllers anyone?
powerdrives.net
Prettig weekend en wees voorzichtig, Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
• E-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC •
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
