Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
AXI 5330 8mm shaft
Old 05-13-2007, 07:37 PM
patternflyr
My Feedback: (17)
patternflyr's Avatar
Default AXI 5330 8mm shaft
Just courious if anyone out there is using the new 8mm shaft in place of the supplied 12mm one? I just wondered if these things are strong enough for the size props we are using in pattern? I believe it is solid aluminum and not the hardened steel shaft that a lot of other engines/motors have. The 12mm works fine, but it would be nice not to have to worry about drilling all the props to 12mm.
Emory
Old 05-13-2007, 07:46 PM
Ed Lyerly
Default RE: AXI 5330 8mm shaft
Hi Emory,
I've been using the 8mm shafts for over a year now. Initially, I had a 12mm shaft turned down and re-threaded. Later, I purchased several of the 8mm replacement shafts from Hobby Lobby. I'm running these on 5330/18's on 10S with 18x10 and 18x12 APC-E props. No sign of problems at all. Appx. 2100 watts .
Ed
Old 05-14-2007, 10:00 AM
patternflyr
My Feedback: (17)
Thanks for sharing, Ed. It's good to hear that you haven't had any troubles with that shaft. Anyone else out there using the 8 mm shaft or has everyone else been using the 12mm?
Emory
Old 05-14-2007, 10:21 AM
rm
My Feedback: (27)
rm's Avatar
I've got it on my f3a, only have 45 flights on it, but haven't had any issues with it.
Old 05-14-2007, 04:24 PM
Chris Moon
My Feedback: (8)
Chris Moon's Avatar
I have the 8mm shaft on my 5330-F3A motor and it works fine. Also, the DuBro 8mm X 1 prop nut fits the shaft if you don't want to run a spinner
Old 05-22-2007, 09:29 AM
LCHelilover
My Feedback: (15)
FYI, I sheared one this weekend while tightening it- firm but not "gorilla tight". I had drilled and tapped this shaft for a 10/32 tru turn spinner - so I'm sure it was weaker than the stock shaft which comes tapped for a 3mm bolt. I think in the future I'll attach my spinner with a smaller bolt rather than re-tapping the motor output shaft.
George
