Measuring battery degradation
MA
I read the following on another form:
The increase in internal resistance is also responsible for the voltage drop when you remove the battery from the charger. As a general rule, if the pack drops below 4.0 volts per cell (resting voltage taken 15 minutes after being removed from the charger), it is below 80% of its initial capacity and is ready to be recycled.
Can anyone confirm this statement with actual experience?
RE: Measuring battery degradation
ORIGINAL: Scott Smith
Jim O
CO
A simple way to measure internal resistance is as follows:
Measure the no load voltage.
Measure the voltage under a known load ( A amps) with a whattmeter for instance.
The internal resistance is the (No-load voltage - the Loaded voltage) divided by the current - or (Vnolad - Vloaded)/A.
If the current can be set at one amp, you don't even need a calculator.
Interesting question.
From your experience with electric pattern flying, what is the number of flights that can be done with a lipo pack, before considering it degradated - or at least not as performant as new?
ORIGINAL: Gulliver
I have just started to try this method.
Would have meant more if done when batt,,, were new, these results would be a reference.
At what charge state should test be done
I am using 12.5A load.
Perhaps some people would post results here for reference purposes.
When cycling to check capacity what voltage is recomended to bring the pack down to, and what % of cap,, is left in there at that voltage ??.
Regards
Brian
