Spark F3A, from Krill Models - SPAIN TEAM
#51
For those of you that are interested in the planes please contact Phillip Barnnett. He will be more than happy to help you out get a plane.
His email is [email protected]
I think it may be just enough rudder servo but I'm not sure yet. Kidding...
As far as the airplane goes this is by far the best rolling, snapping, and spinning airplane I have flown. I have flown Integrals, Passports, and many others and this one seems to just be one notch better.
I have been working on CG, Thrust angle, and throws. Now I have them all figured out I'm flying with about 2 percent rudder to elevator mix and no roll coupling. On the downlines I just checked tonight and I'm at 1 percent downline mix.
With the extremely tall fuse the airplane does not drop the tail in knife edge flight. It still takes rudder in order to hold knife edge just doesn't drop the tail like most. The snaps of this plane is where it stands out. With the cut back wingtips it starts and stops snaps extremely quick. My wings are 17 ounces ready to fly but they have no signs of interia in the air.
The quality of the Krill is pretty awesome. This is my second Krill and the quality just keeps getting better and better. If you guys would like I can take more detailed pictures.
Andrew
Andrew
#54
My Feedback: (41)
I like the newer version a lot better.I find theplane a look that kind ofgrows on you.
I agree with you Andrew about the snaps and spins. I've been watching Dave Snow fly his all springit looks great in the air.
Kudo's to Krill for an innovative design. Mike
#57
ORIGINAL: woodie
For those of you flying outrunners in your Spark, how about some pix of your mounting approach?
thanks
Woodie
thanks
Woodie
http://krill-model.com/download/spar...stalengine.htm
#58
thank you for the pictures. If you follow the pictures, it appears over time that carbon cloth was added to the entire nose instead of 2 horizontal strips coming back from the nose. Any idea if those were added by the builder or has the Spark 'evolved' to include the carbon cloth reinforcement in the nose?
Woodie
Woodie
#59
Andrew,
Where is your CG?
I am also building a Spark and only need to get a good idea of the CG before the maiden.
Randy
Where is your CG?
Randy
#60
Woodie.
The first pictures shows my PROTOTYPE which where the last one before production.
The carbon cloth in the nose is something that has evolved at the factory.
#62
ORIGINAL: joenella
Randy
I have my CG just on the wingtube edge.
Randy
Joe, just to make sure that I understand: your CG is at the leading edge of the wingtube?
Randy
#63
Here are a couple of pics of my setup with:
Neu 1515/3D 6.7:1 HD gearbox
CC HV-85 ESC
20x12E Mejzlik Prop
2 ea Flightpower EVO 5350 F3A batteries
This combo flies my 11.5 pound Extreme Flight Yak-54 twice through IMAC Sportsman routine with plenty of power and battery life to spare. So the same setup should fly the lighter and more aerodynamic Spark with no problems. The motor attached to the front firewall using a piece of 3/16 ply with 1/8 inch neoprene between the ply and the firewall. In the pic showing the back of the motor, the support in the rear is the optional Hacker motor mount from Krill with some wire hangers used as spacers until I find the right thickness neoprene to make spacers. The back mount is quite nice since it allows a good range of movement for possible thrust angle adjustment.
Hitec HS-7955TG for rudder and ailerons
Hitec HS-5245MG for elevators
I also have but did not install an MK elevator bellcrank. I left a servo pocket open behind the rudder servo if I ever decide to try that option. Also, rather than run two 3-wire servo leads to the rear, I made up a 4-wire cable terminated into two plugs at each end so that I can program the servos with the horizontal stabs installed to get the best possible matching. The 4-wire cable has two leads for power and one lead for the signal to each servo. Pull rigging uses crossed Kevlar lines, rather than straight like Flyboy91. This moves the exit from the fuse back about 2cm closer to the leading edge of the horizontal stabs.
JR R-2000 SPCM receiver
2s-1300 Fullymax LiPo with CC-BEC set for 6 volts
All up weight is right at 11.00 lbs. I can lose a couple of ounces by going to a smaller LiPo to feed the BEC, or by switching out the metal gear servos in the elevators for plastic geared servos, or by replacing the elevator servos with a single servo in the fuse coupled with the bellcrank. I could also use the Neu F3A motor or switch to another 1515/3D motor with the lighter 6.7:1 gearbox, which is now installed in the Yak.
CC HV-85 ESC
20x12E Mejzlik Prop
#65
Andrew,
Thanks! I will start there and report back to the group. That position for CG will put my batts directly over the langing gear bulkheads. Also, that position is consistent with roughly 25-30% MAC.
Coincidentally, your plane is the same color scheme as mine - nice choice
Randy
Randy
#67
Hi Andrew,
I`am thinking of going to E-power and have been looking for a plane that could be competitive for the upcoming FAI(P-11,F-11) sequences and honestly thought that the Spark wasallitle outdatedfor the new schedules as it beeing in the marketfor almost 4 years now but looks like i have to rethink that lol.
What made you choose(flying wise)to campaign the Spark for 2009 and supposedly the Worlds in Portugal later this year in August?.
Do you think that the Spark having those special design wing tip leading edges has an advantage in snaps and spins and rolling maneuversas you stated in a phew earlier posts over the Integral and other planes that you flew before?.
How does the Spark handle crosswind situation as we basicallyhave to fly every weekends in crosswind?.
Please post pictures of yourcustom schemes when you get them?.
Thanks for your help.
Best regards.
Best regards.
#68
The reason I'm flying the Spark is I feel in my personal opinion it is the best airplane to date I have flown. It has excellent rudder authority for all the rolling maneuvers and a great look in the air. The wings really help with Snaps. For me this is the best snapping airplane that I have flown. It starts and stops right when you want it to, this is even with them being heavier than foam wings.
As far as the plane in crosswind I would say that I have not found it hard to keep a line. The rudder is very effective on the Spark so you have to get used to giving just a little bit of rudder at a time.
I have attached a picture of the plane at the factory.
#69
Hi Andrew,
Thanks for the quick reply really helpful,the Spark will be absolutelly be on top of my list for my E-conversion.
Looks like a very interesting plane although it doesn`t seem to be a very popular airframe in the US?.
I wasn`t that interested in the Spark till now that you gave your observationon the flying qualities of the airframe.If it`s good enough for you..!!! it must be a great flying plane.
BTW your scheme looks awesome thanks for postingand we hope to hear the flight report.
I hope someone can make some videosof the 2009US Natslike the ones they taped in 2007 inMunciethat were posted in the District 4 website?.Of you flying the Spark and the other finalists,that would be great!!.
Regards.
Regards.
#71
Chief Aircraft http://www.chiefaircraft.com/rcmsec/Models/Model.html is now a U.S. distributor of the entire Krill line of airplanes, including the Spark. When I decided to buy a Spark, I tried to get in touch with Phillip Barnett several times by phone and email and received no response. I got in touch with Ivo Kryl at the factory, and made all the arrangement to get the plane to the U.S. After several very nice and helpful email from Ivo, and after having several pleasant dealings with Chief Aircraft, I recommended to Ivo that he contact Chief to see if they were interested in carrying his planes.
Chief has a container of Krill airplanes, including some Sparks, on its way from Czechoslovakia, arriving around the end of June.I suspect that if you want to get one of these, then you should contact Chief soon.
I am not sponsored or otherwise beholden to any manufacturer or their reps. My opinions are completely independent.
#72
ORIGINAL: sd_raptor
Chief Aircraft http://www.chiefaircraft.com/rcmsec/Models/Model.htmlis now a U.S. distributor of the entire Krill line of airplanes, including the Spark.
Sent: Thursday, June 04, 2009 1:19 PM
To: [email protected]
Subject: RE: Krill Models
Bill,
The Spark will be available under special order only, we at Chief Aircraft Inc. won’t stock the plane just due to the fact that it’s expensive and out of the normal lineup of airplanes that we stock, I’ve emailed the factory and I’m waiting a production schedule and costs. I’ll advise once they contact me.
Thanks for your interest.
Dana Blix
Dana Blix
Chief Aircraft Inc.
Phone: 541-476-6605 x4019
[email protected]
#73
Hi Flyboy....great job !!!!!...
With regard to fly cross-wind, we had our doubts when deciding whether to opt for the original design ...
Experience after more than 350 flights showstheir behavior is very good, and basically do not copy the unstable areas of differences in air pressure (in summer, essentially)
Comments from pilots who first appreciated the quality of flight, emphasizing the high stability in adverse conditions of strong winds.
This year will fly in WC Portugal at the hands of my son, the pilot.
For the moment, in Spain are already 4 Spark flying in competition.
greetings to all.
greetings to all.
#74
The airplanes have made it to my house. It was a little bit of fun trying to get them out of customs but after all the calls it was well worth the wait.
I got 2 airplanes which are very similar. The big difference is the canopies. One of which is the black carbon the other the tinted blue. I will get another blue and carbon to make sure I have spares for the worlds.
Pics attached...
Pics attached...
#75
Andrew,
great color scheme - should be very visible in flight and attract plenty of attention on the ground. Must be nice to have some artistic ability!
Like you I had an interesting time at customs: they could not seem to comprehend why I would buyanother plane when I already had more than 10.Being that the Customs officer was a woman, I considered asking how many pairs of shoes she owned but since she was wearing a gun, I used discretion. After copying my AMA card, club membership cards in two local clubs, looking the clubs up on the internet,and grilling me for two hours, they let me pay my $9 processing fee and get my plane. To complicate matters I did not bring my invoice from Krill showuing the price in dollars and only had the bill of lading with the price in Czech currency that was more than 10 time the price in dollars.
