Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Sebart Angel S Evo 50E
Old 11-28-2015, 11:59 AM
  #51
vilelas
I m flying one in portuguese f3A cup....
Old 11-28-2015, 03:45 PM
  #52
BaldEagel
BaldEagel's Avatar
Vielas
Is that an electric version or IC, whatever it is what's the specification? I have both, one with and AXI and one with a West 50, haven't flown either for a while as I have been a bit busy.
Mike
Old 12-01-2015, 03:24 PM
  #53
vilelas
I m flying the eléctric
Old 12-01-2015, 03:27 PM
  #54
vilelas
My setup is RC plus digital servos 16#8 prop and axi 4120 motor .
Old 12-01-2015, 04:13 PM
  #55
BaldEagel
BaldEagel's Avatar
I put a 4130/16 in mine, had it over from something else and it fitted, unlimited performance on six cells, digital servo's on all surface's, but I think I prefer the IC version as it has a longer duration and seems to grove better being that little bit heavier on take off.
Mike
Old 08-19-2017, 11:37 PM
  #56
Rudix
Rudix's Avatar
The Sebart Angel S EVO 50e might be long out of production but I found one, new in the box, for a great price. I am hoping it will be a good tool to use to get back into pattern after around 20 years. The kit was complete other than the spinner and wing mounting bolts, since the bolts are 4mm they were easy to find.
The plane is equipped with an OS 5025-375 motor running on 6S 5000mah packs swinging a 16x10E APC prop. I am using a Jeti spin 99 ESC. On the ground I can see that I might have to go up one prop size but for now I will fly it the way it is.
As you can see I still need to get a spinner!
Next on the workbench is a Sebart MythoS 50e and then a 125.
Rudi
ID:	2228590   Click image for larger version
Last edited by Rudix; 08-19-2017 at 11:46 PM. Reason: Database errors messing up images!!
Old 08-20-2017, 12:07 AM
  #57
bem
Hi,
I have the smaller Sebart Angel S30E and it flies very well. The 50 seize version should give You many enjoyable flights.
(I have also Sebart Wind S50E, the model that came after Angel S50E, and other Sebart models like MythoS 125E and MythoS Pro).
One in our club has an Angel S50E but he use a Saito 4-stroke engine (there is a glow engine mount avaliable for this plane). Flies great.
Have fun and welcome back to to pattern flying.
/Bo
Old 08-20-2017, 03:55 AM
  #58
Rudix
Rudix's Avatar
Originally Posted by bem View Post
Hi,
/Bo
Thanks for the info, yes, it looks like a nice plane, hope to maiden it one afternoon this week, still need to setup a few things on the radio. The Sebart planes are really well made! I can't wait to get stuck into my MythoS 50e and then the 125. There is also a pro at one of the local hobby shops, might just get it for later. There are no local motors for it so I would have to import that but that is not a major problem, just take a bit longer so needs better planning!
Thanks, nice to be back and a new challenge, planning to practice intensely the rest of this year and then start entering contests next year.
Rudi
Old 08-20-2017, 09:23 AM
  #59
ltc
Very rare find!
white/green/red hasn't been offered by Sebart for a few years now
Best of luck !
Old 11-06-2017, 06:26 AM
  #60
Rudix
Rudix's Avatar
A quick report.
My Angel S Evo 50e has now been flown quite a bit, I am using it as a "keep in the car" practice plane allowing me to fly a few times a week after work. I now have it trimmed to my satisfaction and it is flying well with the motor (OS 5025-375KV) being really smooth with more than enough power. I am running an APC 16x10 prop and I am getting 12+ minutes of pattern flying with 40% + remaining (6S 5000mah Gensace packs) so I think the motor is still under propped. I have a 150A telemetry sensor that I will put in the plane to see what the max current draw is like in the air and then decide if I should change the prop.
Early morning practice session.
She has now been joined by other pattern planes but still flies more than the rest!
Rudi
Old 11-27-2017, 10:08 AM
  #61
Rudix
Rudix's Avatar
More flying with a current draw telemetry sensor showed that the OS 5025-375Kv only drew around 42A on take-off and less in the air with the 16x10 APC prop. I have now changed the prop to a 17x12 APC. On take-off it now draws 66A and then drops to a max below 60A in flight (only on verticals, level flight is below 30A). This is perfect still giving me an easy 10 minutes plus and unlimited verticals. On landing the motor/ESC is barely warm to the touch.
This seems to be a bit more prop than what OS suggested but since I am flying at a ground level of 5000' (up to 9000' + density altitude on a summers day) that could explain the difference. She is now really a pleasure to fly with the trimming mostly complete. She flies a bit faster than my other "F3A trainers" and that is just perfect for a windy day.
The graph below shows the current draw (green line) and the throttle setting (red line) of a short flight with the Angel, the data is from the telemetry log. I still need to change the throttle curve a bit (linear at the moment) to get my "cruise" throttle setting to be at about mid-stick the way I prefer it.
Rudi
Old 09-15-2020, 08:10 AM
  #62
Rudix
Rudix's Avatar
I just noticed my old posts here while searching for something else, well, 3 years and lots of flying later the Angel S evo 50e is still flying well! She is still in perfect condition and I fly her on a regular basis as a fun flying plane with a bit of F3A practice thrown in.
Ready for action at my private desert strip.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
