Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
Sebart Miss Wind S 50E
Old 06-21-2010, 04:08 PM
  #301
Roberto B.
Default RE: Sebart Miss Wind S 50E
Rhino 6s 4900. 730gr. (as stated on hobbyking web site)
Old 06-21-2010, 04:44 PM
  #302
madfreestyler
Interesting...... I have a 4900 but thought it might be too heavy so have been running the 3700's instead. Do you 3d yours with that battery?
Old 06-21-2010, 04:54 PM
  #303
Roberto B.
I had only 5 flights on it. For pattern was great. For 3D I don't know, but I suppose it's ok. Of course, the lighter it is, the better it is.
Old 08-08-2010, 08:01 PM
  #304
lablover
Would a Eflite 46 brushless and a Castlle 75 Ice and 5 cell 5000 mah fly this thing? I'm mostly a nitro guy but this baby is purrdddyyyyy
Old 08-09-2010, 02:14 AM
  #305
Roberto B.
Absolutely not!
Adequate power is, for example, this one that I use: TGY AerodriveXp 90 SK Series 50-65 380Kv / 1820w
with a 6 cell 4900mah apc 17x10
http://hobbyking.com/hobbycity/store...idProduct=7070
Old 08-09-2010, 06:53 AM
  #306
lablover
So a Eflite power 60 might do the job...The reason I ask is I have eflites on hand here at home...the 46 and the 60 I also have a spare castlle 75 amp ESC
Old 08-16-2010, 04:47 AM
  #307
Velco
Velco's Avatar
My Miss Wind is ready, the only things left to do is to set the CG and program the radio. I am using JR9303 and it doesnt have a bipe mode so I had ordered Y cables, but luckily I have just stumbled upon this:
ORIGINAL: AWorrest
When you are referring to having four aileron servos, if you mean one servo per aileron, the 9303 is very capable of handling it. Simply set the wing to normal. Mate an inhibited channel to aileron and mate another inhibited channel to flap. Then use two or three program mixes. One to mix aileron into FROL. A second to mix RTRM into FROL. If you want the right trim switch to trim both sets of ailerons, use a third mix and mix RTRM into AILE.
If you mean having two servos per aileron, then there seems to be no way of intrinsically matching the movements of the servos in the ganged pair. The 12X has this additional function. But you should expect the 12X to have more features. After all it costs about twice the price of the 9303 and only has one-third more channels.
Allan
I will try this later this week and post my result.
Old 08-16-2010, 03:27 PM
  #308
john agnew
Velco
Mine is ready to fly too! I took it out to the field today as the weather was perfect, only 2/3 mph of wind and around 18oC. I set everything up and turned on my Futaba 14MZ, pressed the screen "Yes" prompt to transmit, nothing happened!, pressed a bit harder and the screen cracked![:@] The "Yes" prompt has been getting harder to operate on the touch screen for some time and I understand it is a fault on early 14MZ's. So, packed it up and back to Futaba for a £200 new screen!
BTW the 4 servo wing setup on the 14MZ is very simply, just designate the top wing ailerons as aileron 3 and 4 and assign the J1 stick and T1 trim to these channels and you are done, individual sub trims and ATV's for all four ailerons.Loved the MZ until today!
John
Old 08-17-2010, 05:24 PM
  #309
Mastertech
My Feedback: (31)
Mastertech's Avatar
Would a Eflite Power 110 and an HV85 do ok in this airplane?
I'm a newbie to elect's so please bear with me.
Old 08-17-2010, 06:13 PM
  #310
burtona
My Feedback: (50)
I have the recommended Hacker A50-16S in mine and with 6S 3700 Rhino. It flys pattern sequences very well with plenty of power for any style. I don't do 3D stuff anyway so I don't have an opinion on how it does that.
This plane is considerably smaller than a 110 size plane. I think the E-Flite Power 110 and an 8s setup would be big overkill and probably a chore to install. An Axi 4130 on 6S would be a better setup I think but it will still require some carving and gluing work installing I'd think whereas the Hacker is just a bolt in.
Old 08-17-2010, 06:37 PM
  #311
Mastertech
My Feedback: (31)
Mastertech's Avatar
Hows that stand working out for you?
You planning at being at the Lake City contest inSept ?
Old 08-17-2010, 06:43 PM
  #312
burtona
My Feedback: (50)
Stand works very well, It lives in my plane trailer so it goes where the planes go.
I do plan to be at the Lake City contest.
Dave
Old 08-17-2010, 08:29 PM
  #313
Mastertech
My Feedback: (31)
Mastertech's Avatar
I'll be there, not sure I'll be flying or not. I have some planes to try and sell and sure would like to take a look at your Miss Wind.
Old 08-17-2010, 10:08 PM
  #314
jthomas235
jthomas235's Avatar
Hello all,
I've spent a few nights researching the miss wind and am very interested. If I wanted to purchase a new kit, who handles them in the USA? Do any of you guys have a RTF for sale?
Regards,
John
Old 08-17-2010, 11:22 PM
  #315
burtona
My Feedback: (50)
Try Chris Moon - F3A Unlimited
http://www.f3aunlimited.com/miss_wind_50.html
Old 08-20-2010, 08:47 PM
  #316
Mastertech
My Feedback: (31)
Mastertech's Avatar
Ok so I oredered the plane from F3AUnlimited.
Batteries from HK
so now...........
Hacker A50-16s
CC Phoenix Ice 100SB
APC 16x10E
4721 on Elev, Rudder ??? I have some and some 8311's and 8411's
Also some 3411SA
What JR servo's for the ailerons?
or just go with the HS 5065MG?
Anything else?
Tim
Old 08-20-2010, 11:34 PM
  #317
burtona
My Feedback: (50)
I used one JR-9411 on elevator, one JR-9411 on rudder, and four HiTec HS-65HB on ailerons.
Old 08-23-2010, 08:27 AM
  #318
Velco
Velco's Avatar
Please check Sebart site, Seba has published a new final setting for the Miss Wind 50.
Old 08-24-2010, 06:14 PM
  #319
jthomas235
jthomas235's Avatar
I will have a miss wind in my hands in about 2 weeks and am at a loss with what batteries to use. This will be my first 6 cell aircraft but have used 2 and 3 cell LiPos in a couple of different helis and smaller airplanes.
I'm not a 3D guy or have a desire to fly competition (IMAC or FAI) but do like that style of flying. Call me a sport flyer who likes precision aerobatics. Having said that, which battery will best suit my needs? I've looked at prices from several suppliers and if possible, would prefer to use something like a HK Rhino ($89 , 4900 mah, 25C, 791 grms.) or maybe the Zippy ($47 5000 mah, 25C, 836 grms).
Will these work? Or, do I need to open my wallet wider and go for some of the other more popular brands that run $175-$200.
John
Old 08-24-2010, 06:32 PM
  #320
Roberto B.
I use the Rhino 4900. I get 8 minutes flight time with 25% mah to spare.
Old 08-24-2010, 07:50 PM
  #321
burtona
My Feedback: (50)
I use the 3700 Rhino packs in mine but I already had them from another plane. I would get the 4900 packs if I were to order more.
Old 08-24-2010, 08:01 PM
  #322
Mastertech
My Feedback: (31)
Mastertech's Avatar
Got mine from F3AUnlimited today. Everything else should all be here by Friday.
Should make for an interesting weekend.
Going with JR3421SA's in the tail and HS85mg in the wings.
HackerA50-16 and a CC esc. 16x10 prop.
I've never cared for the tail wheel into the rudder post, anyone do a tiller arm style?
One thing I don't like so far is the screw in the battery cover. I might try to figure out some sort of quick release.
Perhaps magnets. Anyone try that yet?
One thing I got that I don't see on the plans/booklet nor any pictures.
There's two sheets of red plastic something , no idea what they are for yet. Somewhat tear dropped shaped.
Old 08-24-2010, 09:57 PM
  #323
burtona
My Feedback: (50)
The red tear drop thingies are fairings for the aileron servos. I didn't use them on mine.
Old 08-30-2010, 02:02 AM
  #324
Roberto B.
This the way I installed the regulator in my plane. In my previous Miss Wind (totalled), the battery pack went in the VR that was installed just in front of it.....
Of course now it runs MUCH cooler.
Old 08-30-2010, 02:47 AM
  #325
radek
Now that is a proper install, clever thinking Roberto! This even looks cool.
