Hacker A60 with Jeti Opto Spin 99
Hi to all,
someone can help me to configure the Hacker A60-22s with the Jeti 99a Opto Spin?
Thank You
Francesco
Italy
Thank You
Francesco
Italy
For setting this up I would run:
For Prop an 18x12 seemed to work well for me
24 Degrees of timing
Automatic end points
Auto Lipo cell count
2.6 volts per cell cut off
8khz
I personally do not run any brake on this motor so you can use that if you feel necessary.
Andrew Jesky
ORIGINAL: flyboy91
8khz
Andrew Jesky
8khz
Andrew Jesky
Francesco Izzo
