Is 4350 mAh enough for F3A schedules
Hi
Thunder Power has new 4350 mAh 20C pack. I need a few extra grams on new plane, any pilots out there with experience on flying 4350 mAh packs in F3A competitions If applying the 80% rule should not draw more than 3500 mAh out of the packs, this is within my current power consumption, some comments please.
Regards
Burt
Regards
Burt
As long as you stay within the '80%' usage range, should be ok. I think several people were running those packs in FAI at the Nats.
Woodie
Woodie
Depends on the motor: In my experince it is OK on a Hacker 13 XL Comp (would be OK for a 14 as well) limit extra maneuvers. Figure 3000 mAH nominal/flight. Likely not feasible on an outrunner.
Andre Bouchard
Andre Bouchard
ORIGINAL: Dre
Andre Bouchard
Andre Bouchard
Woodie
I used a 4350 mah Tanic pack (with Enerland Cells ...) last year in Masters with a Hacker C50-14XL, and a 21 X 14 APC prop on an 5 kg Integral, and I was drawing about 3000 mah to 3500 mah per flight.
The only complaint that I had was that after the pack had 75 to 100 flights on it I couldn't draw more than 3200 mah out of without risking have a cell go below 3 volts. In FAI there are 17 maneuvers versus 19 in Masters, so it should work fine, but I think you'll have to replace your packs at the end of the season though.
