Cheaper batteries, what have we learned?
TX
There was quitea bit of interesting discussion and experimentation late last year on cheaper battery brands (Zippy, True R/C, Rhino, Flightmax, etc.).Now that some time has passed, and many of usneed to buy batteries for this season, it would be great to revive that discussion and see what the experience over time has been with these less expensive brands as well as havediscussions on any new developments and battery options that may now be available.
If you've tried any of these less expensive batteries please share you latest experience and viewpoint on the reliability/suitability for competition pattern flying.
Keith B
Keith B
Here in Australia the cheaper batteries are going quite well. There were a few puffed packs early in the piece but they seem to be pretty good now.
Personally I spend a little extra and use Thunder Power. Why do I do this??? They are significantly lighter for one. Secondly, the back-up support is very good.
If the cheaper packs can be made lighter then I might give them a go.
Cheers
Jason.
Cheers
Jason.
I started 3 yrs ago with LiPolice 15C (probably just some re branded Zippy) and was completely disappointed. After that I bought Kokam H5 30-50Cspending over 1000$ and was happy with them until I tried Rhino some 18 months ago. Much lower internal resistance in the favor of Rhino.
In the mean time I tested Flightmax and Turnigy. On one Turnigy 6S 3600 30C after just ten flights one cell just died, luckily not in the air! Flightmax were 4S 2650 30C that were quite OK.
As my small Rhinos are still performing flawlessly for this season I have purchased 6 packs 5S Rhino 4900 25C and 4 packs 4S 2250 40C to be used on all of my planes.
Velco
TX
Isure was hoping to get a better discussion going with this topic. It's something I'm sure a lot of people could benefit from.
Anyone else have any input?
Keith B
Keith B
My Feedback: (12)
FL
I agree with Velco, my 6S Rhinos are going well, I don't have anything else to compare them to but I have no problems with them and flight times and power have been what I was told to expect with my set up
NY
I have two [link=http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7654]Rhino 4900s [/link] (1255g/44.5 ozs and $65) that have approximately 30 cycles and are just under a year old. They still have ones and twos for resistance numbers, hold their voltage above 35 volts in flight for a minimum of 8 minutes, and always come down cool to the touch. I have one set of [link=http://www.espritmodel.com/index.asp?PageAction=VIEWPROD&ProdID=10753]Thunder Power Prolite V2 5350[/link] s (1170g/41.5 ozs and $210) that is just over a year old and has about 40 cycles on it. The resistance numbers are fives and sixes and the battery is coming down hot if I push it to 8 minutes. 7 minutes seems o.k. It holds 33 volts minimum in flight. I also have data on a TrueRC pack and I think I even have graphs from "then" and "now" for all the batteries, but sadly I have to go to work until Monday night so I'll have to add more to this discussion next week. I would also note that [link=http://www.electric-f3a.com/]Electric-F3A.com[/link] has some great data to keep those interested working for a while
My short answer is the Rhinos can't be beat so far, and Thunder Power will need to adjust their pricing enormously if they are going to remain viable.
Joe
Joe
Nice try Keith, probably the best comparison is $/flight as use habits will vary the parameters during life making comparisons difficult at best. Number of flights until batteries are unusable divided into cost is pretty definitive.
Unfortunately it takes a good deal of time to reach the end of life for most good batteries. I've generally observed "premium" packs available cost around $2.50/flt or less, that's generally 150+ cycles. That number has improved from around $4/flt a few years ago. It'll take a while for the performance of the current "new tech premium" packs to be determined - but prices are lower and expectations higher - time will tell. My experience with the "premium" packs is that preformance and reliability have continually improved with time to the present. "Last years" packs were excellent and the expectations for the current tech are even better. So overall a good value considering price & reliability.
My observations of the "low price" packs being used by others is that they are generally performing well, tend to be a bit heavier, and some are better than others. OTOH, these only need exceed 60 or so flights to be cost competitive. Just not enough info yet to reach any valid conclusion as to their long term value.
From my view there's more to value than just price - but that's me.
My three Rhino 10S 4900mAh packs have seen 60 flights sofar and I don't notice any significant performance loss to date on them. I did have an issue with two packs reviving after winter (I stored them in my garage which was quite cold this winter for prolonged time which I think was a bit too much).
Regarding internal resistance I have become a little carefull since this seems to vary a lot with temperature. My best reference is to measure immediately after flight. My packs now measure at 12-18mOhm on 10S after flight which is still good.
With the high nitro prices over here I am flying for free as of now.. As far as I can see there is no reason why I should change these packs now so this could be a cheap summer!
Volkert
Volkert
TX
I’ve been looking at some of the packs that Hobby King has listed. The Zippy Flightmax 5000mAh 5S1P comes in both 15C and 20C with the 20C being about 84 grams (2.9 oz) heavier for two 5S packs.Has anyone tried the 15C packs? These look closer to the TP Prolite V2 packs.
KeithB
KeithB
ORIGINAL: 2Sunny
Joe
Joe
That sounds very poor, I have flown the 5300 PL2's since July 2008 (I have two of the 4 original packs made up for the 2008 Nats), those combined with 4 newer packs have never been that poor after only 40 flights, in fact the ones are 100+ cycles are not that poor! I have discharge curves that show a new pack compared to an 80 cycle year only pack and there is only 1%-2% difference in voltage between the two.
You should talk to TP about that battery, I think they are warrantied for a year, and they should be performing virtually as new based on the age.
Hi Joe
I have 4 x 4350 mah 10S TP , more than 80 flights each with my Integral, Hacker C50 XL 13 engine - 21 X 14 E APC, and 7 x 4350mah 6S TP for my Miss Wind 50 S
They run cool, +15 degrees celsius after an 8 mn flight, and never go below 37 volts for the 10S
TP are light, and I don't notice more than 2% difference compare to a new set.
I have higher IR numbers than yours from the beginning, but they are very stable
The new G4 models should be cycled 300 times........
I have 4 Flight Power 5350 F3A 10S, 2 years old, that were unbalanced when charging with the TP 1010C charger and FP balancer after 75 flights
After 100 flights and using the Cellpro 10S, they are competitive again
Maybe a good charger could help.
The 1010i+, same as the NEU X10 charger is the next one I want to try, similar to the Cellpro 10S, more expensive, but having the same functions plus a discharge capacity to 7 A.
As Chad said, you should talk to TP.
JP
JP
NY
Chad & J-P,
Thanks for the support. After encouragement from you and my mentor C. Moon I have decided to contact TP about my battery set. It was one of the first sets that I tried to do everything just right with from the beginning and have always used my CellPro 10S to charge them. I am aware that my experience is NOT the norm so I can only assume that a) I did something to harm them b) I have a set of lower quality than normal batteries. In any case I will be contacting TP to see if they can help.
Thanks again for the advice!
Joe
Joe
Keith, I just retired two flight packs of the Zippy Flight max 15C, I run a Pletty. They both had around 135 cycles, and were plenty strong until now. The weight is virtually the same as the TP 5300, at 1/4 thecost, so I think they were a good deal. I just ordered some more of these. Now, theTP feel like Zippy's on steroids, but they are plenty good for practice, at least for my money.
Dale
Dale
TX
ORIGINAL: dolstinske
Dale
Dale
Keith
Keith, Yes these are the new TP 5300 Prolite V2 that I have, at full throttle, they have more power than the Zippy's, but I really don't find I need it.
Dale
Dale
LA
I'm just going to stick with Thunder Power because that is who I have been with forever and I have never had any complaints with any of my flight packs.. A couple of pattern guys at my field use them, but its just been for practice so far.
My Feedback: (55)
TX
The 4900mah 4S (x2) Rhino packs in my Wind 110 are starting their 2nd year
and still performing well, more power than the airplane needs, so they have been
a great value cost wise for me. I figure when you pass 60 or so flights you're
pretty much flying free with these batteries. As a side note the only battery failure
I've had since I started flying electric was 4S Thunder Power which was replaced
promptly under warranty but I decided they all can have problems so I changed to
the low priced ones. I'm sure the premium brands have much better customer service,
I've never sent anything back to Hong Kong but I can imagine it might be a hassle.
tommy s
tommy s
NY
As promised a little data for the geeky types. Both graphs are from batteries with about 30 cycles and one year old. The first graph is a Rhino pack the second is a TP ProLite V2 5300. The main observation is that the Rhinos hold a higher voltage and produce a higher RPM than the TP batteries. This is not new information as last year I posted several graphs and some of the "pros" on the board caught a mistake I made in representing a certain graph as having come from a TP when in fact it was a Rhino graph and they saw that the voltage was higher than average for the TP. For me the big advantage of the TP is the weight savings, but now there appear to be some other lightweight and cheap options on the way. Fortunately for my Delro I can run the Rhinos and still make weight
that's good info Joe! You mention lighter options for the Rhino other then PRolites 5300. What would those be? I think the Rhino is a great battery but I would like to loose some 80-100 grams if possible but still have ~5000 capacity.
Volkert
Volkert
ORIGINAL: wagen017
Taped together with 4mm connectors it weighs 1220 gr.
VA
Has anyone tried the Blue Lipo from Hobby Partz? I was looking at the 5S 20C 5000 for a 10S setup. Weight is 1220 complete if info is correct. It would be good to buy here than pay freight from HK for Zippies or Rhinos. Plus HK always seems to be out of stock. I'm going to use them in a Impact and overall weight is not a problem as far as 11lb limit. I'll be flying the Interm. class anyway.
Just starting in electric and now have 4 double packs of 4s4000 Zippy's I have only run one of them so far, but this post is on a slightly off topic matter. As my second set was inbound from HK last weekend we had a little "incident" here in San Diego where there was a small explosion and fire at the local FedEx depot. Police, bomb squad, and news vultures all descended. It turned out that a couple of "lithium" batteries had shorted out in a package. They were not the ones I had coming from HK (I got them the next day), but now I
have concerns about the implications of this event to our future of mail ordering them.
2x4s4000 Zippy
Castle ICE75
AXI 4130-20
I have a spread sheet to track performance of the batteries, and hope to maiden the plane in one or two weeks.
2x4s4000 Zippy
Castle ICE75
AXI 4130-20
NY
ORIGINAL: wagen017
Volkert
Volkert
Hey Volkert,
How's the weather over there? Any ash on your car?
Anyways, as to the new options . . . the blue packs shown in the picture above are a set I was lucky enough to be asked to test. They weigh 1167 grams ready-to-fly, have held a higher voltage than my Rhinos, and are rated 25C/5000. If they hold up well after 60 cycles I would say they are a big winner as I believe pricing will be well below TP prices though not as cheap as Zippys or Rhinos. Three cycles since breakin so far so 57 cycles to go
Joe
