Electric Pattern Aircraft Discuss epowered pattern aircraft in this forum
New Sebart Wind 50E
Old 03-24-2013, 06:39 AM
  #551
FinnSpeed
Default RE: New Sebart Wind 50E
The ESC brake and BEC functions do not have any direct relationship so ideally using the brake doesn't affect the BEC output in any way.
There's an indirect relationship though: If using the brake heats the ESC up a lot, the BEC circuits will heat up as well and it's output power may drop as a result. That said, if you monitor the ESC temperature and it doesn't become hot, there shouldn't be any problems with the BEC function either.
Old 03-24-2013, 12:23 PM
  #552
stmdk
stmdk's Avatar
ORIGINAL: RC_Fred
Thank you both for sharing this information, appreciate your feedback.
1. why do you think that when you use the brake you can risk a voltage droping?
As far as I understand you put more load on the ESC when you enable the brake function. Just wondered if the BEC's output voltage would remain stable while the ESC is braking.
A possible voltage drop is just an assumption, therefore I would like to hear your experience.
Using a 17x10 prop by the way.
2. as for my setup, i use a separate Rx bat and using around 40% brake..
OK. Do you have a specific reason for using a separate RX pack on your Wind S50e?
As far as I can see you can do without when using the ICE 100. Just curious...
1. with the Wind50 i fly with a 16x12 but i recentley ordered a 17x10 as you, it will draw more Amp but i need that 2500W output so i guess you are using the right prop.
2. as for the Tx bat there are some points you should consider:
a. somtiems you can pull more Amp than your BEC can deliver
b. my firend didt tied hard his main cells pack and when he was in an inverted fly the lipos just gone through the canopy to mother earth, because he was using a separate Tx bat he could control his plane (no motor)
but without losing it...
BTW, now im flying with the reall thing an OSMOSE 2x2M and i have to admit its another world
cheers
Old 03-25-2013, 12:58 AM
  #553
RC_Fred
<xml><w:worddocument></w:worddocument>Thanks for pointing that out Finnspeed, it’s clear to me now.
Will make sure to put an extra battery strap around the main lipo so it doesn’t bail out
</xml>
Ordered my Wind S50e over the weekend, the yellow version. Should be delivered later this week.
Set up will be as follows:
Turnigy G60 Brushless Outrunner 400kv
APC 17x10E prop
Castle Creations ICE 100 ESC
Turnigy 6S4000mAh 30C Lipo Pack
Futaba 617FS [/i][/b]2.4ghzFasst Receiver
1x Futaba S9202 (Rudder)
4 x Turnigy TGY-390V MG for both ailerons and elevator
http://www.hobbyking.com/hobbyking/s...sec_22_5g.html
There’s quite a difference between the reviews of these Turnigy servos but I will give them a try, we’ll see…
<xml><w:latentstyles deflockedstate="false" latentstylecount="156"></w:latentstyles></xml><style type="text/css"></style>
Old 03-31-2013, 11:25 AM
  #554
bem
Hi,
Mounted skiis on my Wind S 50E and flew today on a lake - still alot of snow here. Fantastic flying day today - sunshine, no wind at all, warm and comfortable in the sun.
The skiis is Du-Bro plastic skiis but the tailskii (stearable) I have made myself. The skiis have no negative effect on flying as I can notice.
It was a lot of other people out on the lake today also, people walking, dogs, golfers (yes You read right) and people curious about my plane and asked a lot of questions - all that came near said "how quite it is" and I replied "it is electric motor in the plane". Many people are really interested to see the planes flying and ask many questions when they come near. You never know who might be interested and perhaps start flying later.
I flew alot today, about 7 hours with just short brake to eat and to carry more12 volt marine batteriesfrom the car to lake so I could charge more. I consumed 3 marine batteries for a total 240 Ah and I lost track of how many flights I made but I think over 20.
Flew some complete N-13 (Nordic) schedules and after some rehearsalI remembered the hole schedule and made about 5 whole schedules. Rest was just fun flying (breaking in 3 new 6 cell 45C 5000 mAh Gens ace batteries). A friend of mine showed up also with his small foam plane and he flew the 4 batteries he had withhim.
Sun really shined today and I feel a little sunburned in my face now.
/Bo
ID:	1868722   Click image for larger version
ID:	1868723   Click image for larger version
ID:	1868724   Click image for larger version
ID:	1868725   Click image for larger version
ID:	1868726   Click image for larger version
ID:	1868727   Click image for larger version
ID:	1868728   Click image for larger version
ID:	1868730   Click image for larger version
ID:	1868731   Click image for larger version
Old 04-01-2013, 12:54 AM
  #555
Esprit88
Hi Bem
Thanks for posting those shots, looks like you had a great day in the snow and sun. It's cold and grey over here in England today.....some time to go before I get to maiden my Wind 50S I think. I have fitted larger wheels already to cope with what will likely to be a very rough runway at the club this Spring.
Old 04-01-2013, 12:22 PM
  #556
Quantas
ORIGINAL: stmdk
Gentlemen,
I’m new in this topic. Let me add a couple words.
I use the redundant power supply for Rx and servo in my WindS 50E:
source A: approx 5.5V from built-in BEC (ESC Turnigy Plush 80A);
source B: 6.0V from additional external SBEC.
Both sources are mixed by twin Schottky diode. So I have approx 5.8V during normal flights and 5.3V at peak moments.
Of cause it’s not a full redundancy – the same 6s battery for both sources. So battery’s health is vital.
Proven with 300+ flights.
Cheers
Old 03-19-2014, 09:42 AM
  #557
Alan W
I just joined the "Club" purchasing a used (yellow) one flown only a couple of times - putting it together last nite I noticed the wing lock-down bolts were missing ...
... does anyone know what size they are ? nothing in my junk bin seemed to fit. Also, were they plastic or metal ?
Thanks - can't wait to get it in the air
Old 03-20-2014, 01:11 AM
  #558
stmdk
stmdk's Avatar
if im not mistaken its:
[TABLE="width: 565"]
[TR]
[TD="width: 549"][h=1]Socket Head Bolt 4x30mm (10 pack)[/h]
[/TD]
[/TR]
[/TABLE]
http://www.hobbyking.com/hobbyking/s...0_pack_b_.html
Old 03-20-2014, 03:06 AM
  #559
ltc
You can also use Secraft wing bolts; a bit easier to install/remove by hand
http://www.f3aunlimited.com/webstore...roducts_id=746
http://www.f3aunlimited.com/webstore...roducts_id=815
Old 03-20-2014, 08:23 AM
  #560
Alan W
thanks to both of you .. hoping to (re)maiden it this weekend !
Old 06-18-2014, 09:37 AM
  #561
Alan W
anyone know what size spinner the Wind50 uses ? I broke the tang off the backplate and need to order a new one but forgot to measure ... DOH !!
Old 07-03-2014, 10:52 PM
  #562
sideshow
sideshow's Avatar
I believe its 58MM. I looking for a carbon spinner to put on my recently ordered Wind. No luck finding one yet though...
Old 07-06-2014, 07:22 AM
  #563
stmdk
stmdk's Avatar
actually its a 57 mm . HK has one with an aluminium back plate.
i bought this one:
http://www.hobbyking.com/hobbyking/s...Search=57%20mm
