ESC ARMING SOUND QUESTION
HI...!
I´m have a little problem with my esc and motor... ECLIPSE II Dualsky 6360-12t APC 20X13 Esc 9036 HV -anti spark 47 Ohm connectors and wires 4 mm STARTING WITH INITIAL THROTLE RANGE CHECK OR STICK DOWN ..THE ESC BEEPS ONCE SOUND LOUD ..ONCE SOUND SOFT...BUT THE ESC STILL ARMING WELL..POWER GOOD..THE FLIGHTS WITHOUT PROBLEMS...THIS WITH BOTH ESC AND MOTORS IS NORMAL THAT...OR SYMPTOM WITH CLOSE PROBLEM... I´M VERY PLEASED IF SOMEBODY BRINGS CLOSER LIGHT IN THE DOUBT |
| All times are GMT -8. The time now is 02:45 PM. |
