9303 Fixed Endpoints
Does anyone have the numbers they use for fixed endpoints on a 9303 with a castle controller. I know Dave listed them before but I can not find them. Thanks
Tim |
RE: 9303 Fixed Endpoints
This is what I used to find them. Don't remember them off hand.
http://www.castlecreations.com/suppo..._endpoints.pdf |
I have used the castle method on two different controllers and have gotten two very different results. On an ICE 75 high ended up at 76, with low at 43. On an ICE 100 high was 25, and low was 20. Could there be that much of a difference. So far it seems they both are working.
Tim |
Typically around 75ish and then I set my bottom based on my idle starting at the center of the throttle trim. 50ish? That has been typical for whatever Castle controller I have used with my 9303.
