X - UAV B17
Hi!
First post... I purchased this foamy off Ebay. Nice B17 but the instructions leave much to be desired. Does anyone have any idea where the battery is supposed to be mounted? There is no cut-out for a battery. Checking the CG, the aircraft is very tail heavy without a 4000aMh 3s 11.1v Lipo way up against the front lower turrets. I'd appreciate any help or suggestions! Tkx!! Doug |
RE: X - UAV B17
would help to know who makes it
RE: X - UAV B17
if its hobby king looks like canopy/cockpit is removeable
RE: X - UAV B17
Hi!</p> Tkx for the quick reply. Here's the B17:</p> http://cgi.ebay.com/ws/eBayISAPI.dll...E:L:OC:US:3160</p> As you can see, the mfgr is X-UAV (whoever that is). Made in China. The cockpit cover is glued so there's no hidden compartment there.</p> I ended up carving out a reservoir up front, bottom side of fuseloge to accomodate the 3200mAh 3s 11.1v Lipo. The battery sits about 1/2 deep into the foam. Velcro holds it good 'n snug. The wires run in a canal I carved out aside the bombay doors to a 5/8" hole feeding into the compartment with all wires.</p> Duct tape matches the aircraft color (lucky me!). That covers 60% of the battery and 100% wires. The CG should work out nicely with the battery where I've got it. I can always add an ounch here/there.</p> Tkx for all the help!! Doug</p> |
| All times are GMT -8. The time now is 08:46 PM. |
