RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   props (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/11456552-props.html)
Mythos125 03-25-2013 10:25 AM
props
Anyone find Pt props pull a lot more amps than an equivalent Mejzlik.
Henning 03-25-2013 01:02 PM
RE: props
What dimensions have you tested?
jetmech43 03-25-2013 01:29 PM
RE: props
I got one and it pulls less than an apc
EHFAI 03-25-2013 01:32 PM
RE: props
Nope, measured in flight, a Mejzlik 20.5x12WE draws a few amps max more than a PT 21x12WE on a Q80-14. Flight mAh similar.
Mythos125 03-25-2013 02:30 PM
RE: props
Benched a pt 20x13 @114 amps.Same setup on a Mez [email protected]olfly 5320 Tp 5000 8s Turnigy wattmeter Os Esc
EHFAI 03-25-2013 02:41 PM
RE: props
As Smooth Pass, I also find the PT to draw slightly less than APC on the bench. Is your motor significantly higher kv than the Q (210), possibly a higher rpm explains the difference?
Mythos125 03-25-2013 02:46 PM
RE: props
Kv on the motor is 277.
EHFAI 03-25-2013 02:54 PM
RE: props
I notice that you're running 8S - my experience is w 10S - explains the higher A than I see. However, considering about 3.5v/c at WOT your motor is turning 700-800 more rpm. Maybe the drag profile of the props at the higher rpm is enough to account for your observed measurements. Seems like a bit much prop for 8S.
Mythos125 03-25-2013 03:03 PM
RE: props
Your right about it being too much prop.I like the speed of the 20x13 but I have to be careful with throttle management.I think a 20x12 is probably better suited to my setup.
