New 2017 2m planes
2 from BJCraft (Immortal and Fantasista SP)
1 from AJ (Element) 'and the Stribog (already discussed) http://www.bondaero.co.uk/2017_Airfr...3_3358272.aspx Already on the pre-order list for the Fantasista ! |
2 Attachment(s)
Hello
Nice plane in Liechtenstein conquest : http://www.rcuniverse.com/forum/atta...mentid=2174673http://www.rcuniverse.com/forum/atta...mentid=2174674 |
Also on for the Fantasista and I'm first (I think)
but the Element should be sweet as well..... |
Originally Posted by papaone
(Post 12239757)
Hello
Originally Posted by Dansy
(Post 12239859)
but the Element should be sweet as well..... I may try to get the v2 110 with the stepped leading edge main wing and put the 110 belt drive for it (if I can get one out of Japan ... The 70 belt drive took a while) The new Fantasista SP has the stepped leading edges on both the wing and stab like the Fantasista Evo, but the SP has a new curved leading edge and wing tip, unlike the previous Fantasistas. |
I have the 70 and I really like it...
Originally Posted by ltc
(Post 12240061)
I have the 70 and 110 Fantasista, as well as the Passion Biplane ... I guess I just like Akiba's planes.
I may try to get the v2 110 with the stepped leading edge main wing and put the 110 belt drive for it (if I can get one out of Japan ... The 70 belt drive took a while) The new Fantasista SP has the stepped leading edges on both the wing and stab like the Fantasista Evo, but the SP has a new curved leading edge and wing tip, unlike the previous Fantasistas. Where did you source your 70 belt drive? thanks! |
Originally Posted by Opvaulet
(Post 12241112)
hi!
Where did you source your 70 belt drive? thanks! Type 50 (who manufactures them) won't ship outside of Japan for whatever reason If you can't get it from HobbyNet, then try Morris Hobbies in Japan (I think they ship outside of Japan) FWIW, mine came with a Scorpion motor which is a Japan only the other motor is a Plettenberg |
Thanks for the info! What would you say are the advantages of the belt drive and what size prop do you use?
thanks! |
I bought the belt drive simply because it was different, and I like to look at things and how they are designed and built. In the YouTube videos of the Fantasista 70 with belt drive, it sounds a bit different.
A 17x10 or 17x12 prop is a good starting point. |
The new Super Fantasista is at the top of the Inagaki web page ... Of course it is gorgeous.
http://www.ctt.ne.jp/~wcraft/ |
Looks like glow powered. Terrific....Also interesting are the flaps. Love that.
Stab design is rather strange. The chord increase towards the tip adds nothing aerodynamically. Just looks different. If they made the wing that way, it would cause significant performance deterioration in certain key maneuvers. I guess it has not flown yet. Once they fly it, they'll know |
Originally Posted by MTK
(Post 12242113)
Stab design is rather strange. The chord increase towards the tip adds nothing aerodynamically. Just looks different. If they made the wing that way, it would cause significant performance deterioration in certain key maneuvers. I guess it has not flown yet. Once they fly it, they'll know There is also the ST (Saw Tooth) version of the Citrin which has the stepped leading edges. I believe Wolfgang Matt designed and flew the Citrin and Citrin ST. |
(Post 12242089)
A 17x10 or 17x12 prop is a good starting point. thanks! |
Hi,
Possibly new plane for 2017: Naruke Hobby "Assist EP" (monoplane): http://narukehobby.fan.coocan.jp/ /Bo |
Hi,
Although already flown by Sebastiano Silvestri during 2015-2016 the Sebart PrometheouS biplane electric is a new plane for 2016-2017 in Sebarts latest Cataloge and price list. PrometheuS biplane With composite fuselage, painted outside mould & Balsa wings & stabs covered with Oracover Price: 2400 Euro including VAT (US $2688) /Bo |
(Post 12242218)
i think you are just like me! One question though, are you on 5s or 6s and do you find the belt drive system more efficient and uses less Mah?
thanks! I never measured efficiency for this plane versus a standard outrunner, sorry I just received an Akiba designed BJCraft Passion biplane with an OS F3A belt drive ... I tried unsuccessfully to get an Akiba designed belt drive out of Japan Maybe the next plane ... |
(Post 12239757)
Hello
Originally Posted by bem
(Post 12242226)
Hi,
Although already flown by Sebastiano Silvestri during 2015-2016 the Sebart PrometheouS biplane electric is a new plane for 2016-2017 in Sebarts latest Cataloge and price list. PrometheuS biplane With composite fuselage, painted outside mould & Balsa wings & stabs covered with Oracover Price: 2400 Euro including VAT (US $2688) /Bo http://www.f3alorenz.de/home-f3a/seb...us-biplane.htm Not sure if it comes with a nose ring for Contra or regular EP |
You can view pix of Seb's biplane on Friday's post at http://jp-f3a.blogspot.de/
JP changes the contents daily because its devoted to the EC F3A. It's deep in the blog and you have to recognize the airplane. J e r Sorry I can't be more specific on its location in the file. |
Originally Posted by JerMilosek
(Post 12243364)
JP changes the contents daily because its devoted to the EC F3A. It's deep in the blog and you have to recognize the airplane. J e r Sorry I can't be more specific on its location in the file. interestingly enough I couldn't find the Prometheus Biplane on the Sebart site; just the monoplane? |
1 Attachment(s)
A Contra drive from Plettenberg?
I saw this in the link you posted...looks amazing ! |
This is your lucky day, LOL, buy a lottery tix.
Prometheus is at http://www.f3alorenz.de/home-f3a/seb...us-biplane.htm I get a couple pulls after you buy it with the Pletty contra. Right? J e r |
Was that a pletty contra drive with a 3 blade prop on the back and a two blade on the front all with small fins on the tips?
(Post 12243379)
Prometheus is at http://www.f3alorenz.de/home-f3a/seb...us-biplane.htm I get a couple pulls after you buy it with the Pletty contra. Right? J e r I've purchased from F3ALorenz before and they were very nice to deal with I would imagine that Mike at F3AUnlimited could order the Prometheus since its Sebart... |
