RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   SBUS Question (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/11645623-sbus-question.html)
preston blake 03-22-2018 04:54 AM
SBUS Question
I have an 18mz and the 7008 reciever. I have the three tail servos on an sbus cable. If I plug the cable into the SBUS2 port, the tail servos work normaly..If I plug into the SBUS port they don't work. My understanding is that they should work on either port. Is there a setting on the transmitter I'm over looking ?
fizzysmack 03-22-2018 05:44 AM
1 Attachment(s)
What mode is your RX in? The SBus2 port is always active but if you don't set the mode to B or D then the 8/SB port will output CH8 or CH16.
Look at the second page in the attached manual.
Attachment 2259598
