RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Installing front mount on himax hc 63 (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/11679327-installing-front-mount-himax-hc-63-a.html)
Mike Pascale 06-03-2020 07:11 PM
Need help to install front mount on himax
hc 63 i have conversion kits for motor
But can't figure out how the front support is attached.
big_G 06-04-2020 05:23 AM
Hi Mike..
I did the conversion, and it mounted with no issues. Once you figure it out, watch the motor temperature. I found that mine ran significantly hotter when front mounted. May not be an issue on your application.
Gary
