Starting with a full inspection of the parts and record of the weights
Fuselage with Rudder and Canopy 1013 g Top Wing 540 g Bottom Wing 549 g Left Stab 92 g Right Stab 90 g Struts and Wings bolts 52 g Total weight 2.236 g Really close to the announced weight on HUI YANG website ( 2350 g) Time to make room on the workbench and start ... https://cimg8.ibsrv.net/gimg/www.rcu...02bbc57ed.jpeg https://cimg9.ibsrv.net/gimg/www.rcu...b2c8a5b19.jpeg https://cimg0.ibsrv.net/gimg/www.rcu...8278780bd.jpeg https://cimg1.ibsrv.net/gimg/www.rcu...b217d8cdc.jpeg https://cimg3.ibsrv.net/gimg/www.rcu...088ae565a.jpeg https://cimg4.ibsrv.net/gimg/www.rcu...54f45ce59.jpeg https://cimg6.ibsrv.net/gimg/www.rcu...4d825cfc3.jpeg https://cimg8.ibsrv.net/gimg/www.rcu...a07d952b7.jpeg https://cimg0.ibsrv.net/gimg/www.rcu...ae3858747.jpeg https://cimg2.ibsrv.net/gimg/www.rcu...9edd26d46.jpeg https://cimg3.ibsrv.net/gimg/www.rcu...e3ec66173.jpeg https://cimg4.ibsrv.net/gimg/www.rcu...e002937df.jpeg https://cimg5.ibsrv.net/gimg/www.rcu...40214c216.jpeg https://cimg3.ibsrv.net/gimg/www.rcu...a7dcfec0da.jpg https://cimg6.ibsrv.net/gimg/www.rcu...e361be84e.jpeg |
Equipment
FUTABA T18 MZ / T 32 RX 7003 BLS 173 SVI Ailerons & Elevators BLS 151 Rudder ADVERRUN SINGLE DRIVE D3 ESC The landing gear legs with wheels pants and wheels weight 168 g ADVERRUN plus D3 ESC 616 g Batteries tray 31 g + 12 g I start with the wings servos installation. Paint is very fragile, and I use a foam protection when working on the surfaces. I found useful using a carbon rod mounted on a plastic horn to position the horn parallel to the hinge line. https://cimg2.ibsrv.net/gimg/www.rcu...41ee8366c6.jpg https://cimg7.ibsrv.net/gimg/www.rcu...938d072c25.jpg https://cimg8.ibsrv.net/gimg/www.rcu...25a3c5266a.jpg https://cimg9.ibsrv.net/gimg/www.rcu...bcf20519bd.jpg https://cimg0.ibsrv.net/gimg/www.rcu...43eda2ecef.jpg https://cimg3.ibsrv.net/gimg/www.rcu...5bc0ef0c2b.jpg https://cimg4.ibsrv.net/gimg/www.rcu...6c9406cf49.jpg https://cimg6.ibsrv.net/gimg/www.rcu...7a0fa20c04.jpg https://cimg5.ibsrv.net/gimg/www.rcu...db4b8fcc78.jpg |
Rudder horn and rudder servo installation
https://cimg3.ibsrv.net/gimg/www.rcu...36702749dc.jpg https://cimg7.ibsrv.net/gimg/www.rcu...cd651b815d.jpg https://cimg8.ibsrv.net/gimg/www.rcu...4b17d47a87.jpg https://cimg0.ibsrv.net/gimg/www.rcu...d8857416a9.jpg https://cimg1.ibsrv.net/gimg/www.rcu...f671b2c9b0.jpg https://cimg2.ibsrv.net/gimg/www.rcu...0c83c94f73.jpg |
Nice. We are waiting for the rest. 😀
Landing gear box reinforcement
Flying from a grass runway, I'm used to reinforce the ldg box with a 1 mm carbon plate, and to add some carbon tissue to distribute the efforts https://cimg2.ibsrv.net/gimg/www.rcu...10aaa3b1b0.jpg https://cimg6.ibsrv.net/gimg/www.rcu...838aed4b09.jpg https://cimg7.ibsrv.net/gimg/www.rcu...01b1bae83c.jpg https://cimg0.ibsrv.net/gimg/www.rcu...cb1b23c227.jpg https://cimg1.ibsrv.net/gimg/www.rcu...a68ba39186.jpg https://cimg8.ibsrv.net/gimg/www.rcu...27caa091ef.jpg https://cimg9.ibsrv.net/gimg/www.rcu...c1694e115d.jpg |
Engine installation.
With the thick nose ring and the short ADVERRUN Drive shaft, I bolted directly the engine to the nose ring using the soft mounts. As the air intake is small, the air exhaust on the bottom of the fuselage seems to be large enough. KONTRONIK runs cool as well as the D3. 80 or 82 mm FALCON spinners are used with a 2 or 3 blades prop https://cimg9.ibsrv.net/gimg/www.rcu...39ecc6fa52.jpg https://cimg9.ibsrv.net/gimg/www.rcu...ce7b5db759.jpg https://cimg7.ibsrv.net/gimg/www.rcu...d38ea97d46.jpg https://cimg8.ibsrv.net/gimg/www.rcu...5f6b2291b6.jpg https://cimg3.ibsrv.net/gimg/www.rcu...5b0d7166f7.jpg https://cimg4.ibsrv.net/gimg/www.rcu...b6bc918862.jpg https://cimg0.ibsrv.net/gimg/www.rcu...a9ad9384cf.jpg https://cimg1.ibsrv.net/gimg/www.rcu...0220dfd514.jpg https://cimg8.ibsrv.net/gimg/www.rcu...04edcd830f.jpg https://cimg6.ibsrv.net/gimg/www.rcu...57cf03e286.jpg https://cimg2.ibsrv.net/gimg/www.rcu...04c1def79a.jpg https://cimg9.ibsrv.net/gimg/www.rcu...780271c6a0.jpg |
How do you like that three blade? Can you compare it to the Falcon three blade in regards to performance?
Thanks, Joe |
Both are very good props
For RS there is juste one size, 21" X 14 For FALCON, you have different models Diameter Pitch 19″ 13.5 EL V2 19.5″ 13 EL V2 19.7″ 13N EL V2 20″ 12.5 13 & 13,5 EL V2 You have too the MEJZLIK 20" 13 EL 20" 14 EL https://cimg3.ibsrv.net/gimg/www.rcu...7fa6584e1c.jpg |
Yes thank you. I was just curious which one you preferred and why? The falcon 20-12 three blade or the RSM three blade?
Final installation
CK AERO tolls for perfect elevators adjustment RX battery and switch plate OPTIPOWER Optiguard for battery backup Clamp filter (ferrite core) to reduce the effects of radio interference by FUTABA recommendation for 7003SB RX - TDK ZCAT1325-0530A https://cimg4.ibsrv.net/gimg/www.rcu...057d7f3a8b.jpg https://cimg5.ibsrv.net/gimg/www.rcu...94d4c19afe.jpg https://cimg8.ibsrv.net/gimg/www.rcu...e21ddbf6e8.jpg https://cimg9.ibsrv.net/gimg/www.rcu...914956921d.jpg https://cimg6.ibsrv.net/gimg/www.rcu...ae90426843.jpg https://cimg3.ibsrv.net/gimg/www.rcu...184f61aa91.jpg https://cimg9.ibsrv.net/gimg/www.rcu...8e4d7676c0.jpg https://cimg9.ibsrv.net/gimg/www.rcu...3023b8c9ca.jpg https://cimg0.ibsrv.net/gimg/www.rcu...e2a182331c.jpg |
Those covers are awesome!
