RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Dsm esc (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/11706746-dsm-esc.html)
rgreen24 05-10-2023 01:43 PM
Dsm esc
Anyone using the Jeti DSM ESC with a jeti tx? If so what the best way to get telemetry from your Jeti ESC?
rm 05-10-2023 10:42 PM
Isn't that just a power sharing device to power your receiver from 2 different sources switching between the highest voltage? ESC telemetry would just be the ext port or e1, e2 with rex rx from the esc telemetry wire.
rgreen24 05-11-2023 02:53 PM
rm - you are correct got some help and figured it out. The red lead would still go in the ext port, however you have to remove the power red lead from the esc so it doesn’t bring power to the receiver
