RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Programming procedure (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/3805535-programming-procedure.html)
OhD 01-21-2006 03:40 PM
I'm in the process of programming a Hacker Master 90-0-ACRO with the programmer. I'm wondering if I need to have the 40 volt power connected and what the sequence of applying power is. Connect the 40 volts, plug in the programmer and then turn on the programmer power? Thanks in advance.
Jim O
OhD 01-23-2006 08:42 PM
RE: Programming procedure
I found the answers to my questions in the provisional manual that can be found with enough persistence on the Hacker Web site. Go to controllers, click on the words Master Series, on top of the page and you will get a page that lets you view/download the manual. You do need to connect the motor power to get the controller to accept the programmer commands.
Jim O
