RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   What spinner for Hacker C50? (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/4147993-what-spinner-hacker-c50.html)
Mike Wiz 04-10-2006 02:00 PM
I have a Hacker C50 Acro going into a Dream 110. It calls for a 2-1/2" spinner. I'd like to use something like a Tru Turn, but I don't know if these will fit the APC 18x12E prop. Do you have any experience with this?
TIA,
Wiz
Gulliver 04-10-2006 02:45 PM
RE: What spinner for Hacker C50?
Just all up truTurn and tell them you want a spinne for an APC prop and they will cut accordingly,
Magne 04-11-2006 12:51 AM
Also keep in mind that you don't need an aluninium spinner with an electric motor. (You are not going to use a starter.) Fiberglass, carbon, even plastic - it all works very well, often at a fraction of the price. Lighter too.
Magne
Mike Wiz 04-12-2006 04:24 PM
Thanks guys!
Malcolm H 04-13-2006 02:45 AM
Hey Magne,
Do you know of anyone who does a plastic 89mm spinner? I am using carbon at the moment but I agree it is overkill.
Regards
Malcolm
Magne 04-18-2006 06:06 AM
Hello Malcolm.
ES somposites do a series in fiberglass, but they have nothing between 80 and 92mm.
3.5"=88.9mm.
Nexus Modelling Supplies do a 3-1/2" nylon spinner for £3.75. I would guess companies like Dubro make 3.5" spinners in plastic.
Maybe not your style, but probably more than good enough at 6000 rpm.
Magne
Malcolm H 04-18-2006 07:33 AM
Hi Magne,
In fact I am using a 92mm ES carbon unit on my Impact.
Regards
Malcolm
