RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   cyclone f3a problems (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/4567584-cyclone-f3a-problems.html)
marzini 07-31-2006 05:13 PM
hi to all
yestarday i run my new f3a cyclone and cyclon controller for the first time, but i have a big disapoint with this brand , after put the bateries and do the program for the esc i start to acelerate the motor slow, pasing mid trothle all was ok but wen i reach full trhotle the engine stop and teh esc was dead , i look the cyclone brand esc and 4 transistor were blow out , teh esc was a cyclone pilot pro 120amp, i was using 2 bateries in series 5s4p so i have a 10p 5300mha and a pac prop 20x12, i write and e mail to the factory and the y said that i have to wait until sptember to send the esc because the are on holydays, and thats all , my question is that a good customer support ? no info whit tthe engine, no info for the esc , so i don nowk wath to do , i think that is my last time with this company
any off yopu have a sugestion
thanks
marcelo zini
sorry for my english
patternflyer1 07-31-2006 07:58 PM
RE: cyclone f3a problems
Sorry to hear of your troubles. September is a long time to wait.
Chris
Sprink 08-01-2006 05:31 PM
Ah, that's France for you. Mainland Europe closes in August, and that's that [:o]
Rather disappointing about the esc as well.
jerome bilquey 08-08-2006 03:11 PM
Hi!
I use the Cyclon F3A too and I had the same problem as yours last month... but my motor runs only 4min :-(
I send back my controler to Electronicmodel and he answered me that the timing I used were 30° and it should be 15°.
can you tell me which timing did you used?
Jérôme... from France... and I agree, Europe stops working in august ;-)
marzini 08-09-2006 04:15 PM
hi i use the timing that fabrice told to me was 7 , now im going to test a hacker master o 90 controller
i will put the test in a few hours
byby
marcelo
jooNorway 08-16-2006 04:04 AM
A friend of mine use the Cyclon 160, nearly simular to the F3A. It works well on a Jeti 90Adv ESC on 10S LiPo.
marzini 08-16-2006 07:35 AM
hi to all
the problem were fixed i put a hacker master o 90 escno more problems
slow aceleration
16khz
15 timing
33 volts cutoff
all is runing ok a lot of power
apc 21x12w at 6300 rpm
marcelo
jerome bilquey 10-13-2006 09:37 AM
Hi!
The new ESC I got (Pilot 120) works very well.
I had some radiointerferences (HF goes through the wire from the ESC to the battery). So I placed a ring just between the battery and the ESC and the interferences goes away
Jérôme
