RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Sebart Angel S Evo 50E (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/6808127-sebart-angel-s-evo-50e.html)
rickhannah 12-26-2007 07:30 PM
Anyone have one of these? Looking for your impressions. Thanks
Aladdin 12-28-2007 07:50 AM
RE: Sebart Angel S Evo 50E
I'm actually using this set-up:
Lipo EVO25 3700mA 6S
Hacker A50-16S
Great combo! :D
It flies great ....nice tracking in rolls and precise in snaps.
jfetter 12-29-2007 11:04 PM
ORIGINAL: rickhannah
I'll have one on Wednesday, I've had one on backorder since August 15, I finally got a shipment notification on Thursday. Anyone interested in a build thread?
JFetter (Jack)
rickhannah 12-30-2007 10:25 AM
A build thread would be great! Now I understand why nobody has one of these, backordered since August? ouch
rickhannah 12-30-2007 10:27 AM
ORIGINAL: Aladdin
Hacker A50-16S
Great combo! :D
Alladin, how long are your run times with the 3700? How about a weight ready to fly?
mikaelmiki 12-30-2007 01:28 PM
Angels 50 are now in stock at www.fedonaircraft.net
Aladdin 12-31-2007 09:45 AM
I usually fly my sport routine (Intermediate) in 6min using 1800mAh with an APC 16x8.
jfetter 01-08-2008 04:38 PM
ORIGINAL: jfetter
JFetter (Jack)
Started a build thread for anyone interested!
[link=http://www.rcuniverse.com/forum/m_6875170/tm.htm]AngelS[/link]
Jack
eoinjoc 01-19-2008 02:48 PM
Anybody have any trouble getting the canopy off. I have split the edge trying to release the magnets...and the only way it appears to work is if the front tongue is removed and lifted from the front.
I 'm not sure if I can lift from the back when the cowl is in place
Eoin
J Lachowski 01-19-2008 04:57 PM
Just got mine. I had a problem getting the wings to fit and then remove. Very tight fit. Yep, magnets on canopy are pretty darn strong.
jfetter 01-19-2008 06:52 PM
ORIGINAL: eoinjoc
Eoin
Make sure when you mount the cowl you hold it UP tight to the bottom rather than tight down, this will leave room to remove it. As for the magnets, they are strong, I usually wiggle 2 fingernails under the top before I gently pry it up. I suppose if they are too strong you could add a layer of foam tape (thin) so they don't touch but you should get used to it...
Jack
eoinjoc 02-14-2008 05:23 AM
Thanks Jack.
Took your advice and it works.
Eoin
ntsmith 02-27-2008 12:54 PM
Been flying mine for the last two moths. Very precise with the stock set up and 6S 30C polys.
Certainly it can be recommended. No probs with canopy or wing fitment.
P-51B 03-19-2008 08:26 AM
Well, I pulled the trigger on one of these on Monday. Hopefully it arrives soon. I have an Axi 4130-16 looking for a home!
Edited to ask: How long does it take to come from Fedon? They charged me for next day air delivery two days ago.
P-51B 03-25-2008 06:11 PM
Well, it got here today, just over a week from the order. I looked at the big parts (no real unpacking yet) and first impressions are that it is VERY nice. I hope to start assembly this weekend.
BaldEagel 04-21-2008 08:36 AM
1 Attachment(s)
You will not be dissapointed, fast snaps will take the canopy off though, I suggest an additional catch, I put an ordinary canopy catch at the rear of the canopy on the top, eventually I bent the handle over to give me something to pull the canopy off with.
Mike
tIANci 07-27-2008 12:59 AM
I think the Angel thread has been hiding here:
[link=http://www.rcuniverse.com/forum/m_6875170/mpage_1/key_/tm.htm]Angel Build Thread[/link]
The DualSky motor that I am using is just right for F3A flying, I am getting about 7 good mins flight time with my Flight Power EVO25 5S 4,900 packs. This is one of the best 40-50 sized plane that I have flown, other plane that I can think which flies so well and clean is the Fliton Exytra 330 Freestyle. :)
oren10 07-29-2008 08:11 PM
ORIGINAL: Aladdin
Hacker A50-16S
Great combo! :D
how does the vertical prefomence on this setup?
Opvaulet 07-29-2008 11:31 PM
Hi,
I have flown other Angel's on that set up. More than enough performance for F3A. I use a higher KV set up though because of using 5S 5300's instead (half of my F3A 2x2 batts)
Cheers
tIANci 08-02-2008 07:12 AM
I been getting a lot more flights on my Angel, I find that she is kinda light and when I execute something like a reversed Cuban, she wants to float a bit at the top. I decided to weigh her and she came in at 2.55 kgs, that's like 5.6 lbs only. Pretty kewl for a 50 sized EP plane of 60".
J-P 08-14-2008 02:11 PM
Just to inform you that I lost today my beautiful Angel 50 , built by Jean-Pierre Zardini.
During the last part of a knife edge loop, the canopy seperated, setting the switch to off.........
I think it could be a good idea to improve the way the canopy is fixed, and/or change the switch location.
tIANci 08-28-2008 10:01 PM
JP - ouch! Sorry to hear that ...
I ordered the HYPERION Z4025/12 for my 5S set up, I hope to see a lot of improvement over my DualSky motor, but I will be using a 16x10 only, I don't think I want to pull that many amps. A report on the motor should be out next weekend!
J Lachowski 03-30-2009 02:00 PM
148 flights and counting;)
tIANci 03-30-2009 08:44 PM
How is your covering holding up? I know designs with sharp patterns look great but they tend to peel off easier with the shart tips. I lost the white trims on the bottom of one wing. Time for more clear nail polish I guess ...
wingster 03-30-2009 09:38 PM
Mine began to peel off on the first flight. I had to go over everything with an iron.
Since then(50 flights) it's been fine.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
