RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   AMA Pattern Max Voltage (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/7852228-ama-pattern-max-voltage.html)
sparky925 08-16-2008 10:56 AM
Has anyone vound the max allowed voltage for AMA Pattern?
I foung the FAI voltage but no reference to ama pattern.
Tony
Troy Newman 08-16-2008 05:08 PM
RE: AMA Pattern Max Voltage
Tony,
The rule just passed by the AMA contest board limits the voltage to the 42V nominal just like F3A. This rule takes affect in january 2009. Current rule for AMA classes.... there is no rule on maximum voltage today. Until January 09' you could run a 12S system if you like. After january 09 this is no longer allowed.
I have some thoughts on another subject that deals with this one too.... Its found in the normal pattern forum as it really is not electric specific.
http://www.rcuniverse.com/forum/m_7853169/tm.htm
Troy Newman
