RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Safety question (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/7943388-safety-question.html)
dreadnaut 09-11-2008 11:15 AM
Safety question
I am starting on my first larger electric project. I will be running 2 3-cell packs in parallel through a Y harness. My concern is that once you plug one of the male connectors on the Y to the female on one of the packs, the other male on the Y becomes ''hot''. Is anyone else concerned about this, and what approach do you use? Also, does anyone have a link to plans and instructions for Y harnesses? I will be using Deans plugs.
TedMo 09-11-2008 12:58 PM
RE: Safety question
I'm not really sure what you're trying to do using a y harness? To connect 2 packs in parallel You should be using a parellel deans connector which will then plug into your ESC.
dreadnaut 09-11-2008 01:34 PM
RE: Safety question
ORIGINAL: TedMo
Because I didn't know about the parallel connector. Thanks for the tip. I found this link http://www.google.com/products?sourc...num=1&ct=title where they have both parallel connectors, and Y harneses.
I am still a little wary of having a ''hot'' male plug dangling about. even for just a couple of seconds. Brain farts often happen in milliseconds.
rcacro 09-11-2008 05:58 PM
RE: Safety question
ORIGINAL: dreadnaut
Just use an extra Dean's connector as a saftey cap on the second end of the Y harness until you are ready to plug in the second battery. You will of course, have to insulate the unsed pins on the saftey cap.
John W.
