RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   TrueRC 10C pack compatibility (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/8430097-truerc-10c-pack-compatibility.html)
elan120 02-02-2009 01:14 PM
Wonder if anyone has direct experience using TrueRC 10C packs with Pletty running 21x14 props? Will this combo work with 10C discharge rate, and how is the voltage holds at the end of flight?
TIA,
Kevin
Chris Moon 02-02-2009 02:12 PM
RE: TrueRC 10C pack compatibility
Hi Kevin.
Several of us flew these 10C packs all last year and at the NATS too with Axis, Plettenbergs, Hackers, Dualskys and they are fine. Dan at True tested these to over 100 amps so they are definitely under rated as far as C rating. There are some newer 15C pack he sells that are a little heavier and are even stronger if you can spare a couple more ounces.
Chris
