RCU Forums
-   Electric Pattern Aircraft (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/)
-   -   Dave Patric Ultimate conversion to Electric (https://www.rcuniverse.com/forum/electric-pattern-aircraft-385/8962769-dave-patric-ultimate-conversion-electric.html)
bigbri 07-25-2009 11:50 AM
Need some advice please. I have a Dave Patric Ultimate I would like to convert to Electric I would love to use 123 cells if possible..I am new to electrics. What do you guys recommend
Brian
woodie 07-25-2009 03:35 PM
RE: Dave Patric Ultimate conversion to Electric
What is the size and projected weight of the Ultimate? I am not familiar with that particular version of the Ultimate.
Woodie
bigbri 07-25-2009 05:23 PM
currently at work. Will get all that info in the morn. Thanks for any help
Anthony-RCU 07-26-2009 09:38 AM
If memory serves that is a 1.20 size plane designed for fuel. This plane would probably need around a 10S lipo set up or 12S A123 and the weight will probably not be very good. Could it be done sure but for you first e plane I would pick something designed for E power from the start.
Ed Lyerly 07-26-2009 11:30 AM
Brian,
This thread contains some excellent info and should answer a lot of your questions:
http://www.rcgroups.com/forums/showt...trick+Ultimate
Ed
